Analog gauge cluster tech
01-31-2015, 05:58 PM
I've been busy tampering with old analog gauge clusters and figured it would be prudent to put my findings in a thread of their own.
My first area of interest was in recalibrating the tachometer to suit different engine configurations and/or different gauge faces (10k redline for example). I dumped most of the info I found in the digital dash thread by accident, so here's a little rehash of that: Quote:http://www.toymods.org.au/forums/tech-co...utput.html Today I took apart a spare cluster and followed up on my earlier suspicions. I put a potentiometer (adjustable resistor) in place of R4, and another one that effectively replaces R1,R2 & R3. Tach signal input: As mentioned in the quoted info, R4 is there to attenuate the coil negative input signal. If you just put a 12V rpm signal on an AE86 dash, it will not work without a tach booster of some sort. If you lower the resistor however (to about 15-16k) it will detect a 12V square wave just fine. With some more lowering it will probably also detect a 5V signal (around 4kOhm perhaps? Found that value on a Pontiac grand-am, which uses the same gauge driver IC) Needle sweep adjustment: If you search around you will find that resistors R1,2,3 have varying values for different applications, even in the same car with the same engine. Electrically speaking, these 3 can be seen as 1 (equivalent) resistor. The reason 3 are used is because it allows them to fine tune the value exactly, something that is otherwise impossible without a potentiometer (which is more prone to drift / sensitive to vibration, not to mention more expensive for production). I noticed most 6 cylinder engines use an equivalent resistance of 8 to 10kOhm, whilst 4-cyl engines like the 4age use values around 15kOhm. Practically speaking, the more pulses per revolution you get, the lower this resistance should be. I found that adjusting these resistors to around the 12kOhm mark would be about right for a 10k RPM gauge overlay. An alternative method exists in which a shunt resistor is placed across the output wires to the gauge, thereby lowering the power fed into the gauge motor. Personally I'm not a fan of this method, it only allows you to adjust the needle sensitivity in one direction, and it's probably not the most accurate way to do it. That concludes the bit about the tachometer.. out there for everyone who might find it useful so they can get rid of fugly aftermarket tachometers. In the meantime I'm researching options to have some alternative gauge faces produced (not just an overlay). Drawing some inspiration from WWII aircraft cockpits: ![]() ![]() I have some OEM style ones in the works.. and perhaps kouki-style pinstripes will also follow. This might be an alternative solution for those with inaccurate speedometers due to gearbox / final drive swaps, I can create just about any scale you can think up.. just needs some careful measuring for solid reference points. Now just to find out what production methods will suit. FABRICA MI DIEM, PVNC! |
02-01-2015, 11:50 AM
(This post was last modified: 02-01-2015 11:52 AM by Bean.)
I will watch this closely, I almost whent down the Racetech dash route but I think it just doesn't suit my car even if the functionality is superb.
If you need a volunteer for kouki 10krpm you know how to reach me
AE86 ex-daily |
02-01-2015, 01:49 PM
Kouki 10k has been done before.. I'm not a big fan of the pinstripe myself but it should end up looking roughly like this:
02-01-2015, 05:10 PM
(This post was last modified: 02-01-2015 05:10 PM by Bean.)
(02-01-2015 01:49 PM)Ivan141 Wrote: [ -> ]Kouki 10k has been done before.. I'm not a big fan of the pinstripe myself but it should end up looking roughly like this:Not a huge fan either but that's what I've got and the speed side is fine being EU kmh spec Who made these and can I order one? AE86 ex-daily |
02-01-2015, 09:34 PM
A Club4AG member had these made for about 150 dollars I believe... in decent quality I might add. Can't remember which shop produced them though.
02-02-2015, 04:14 AM
(02-01-2015 05:10 PM)Bean Bandit Wrote: [ -> ]he made it here(02-01-2015 01:49 PM)Ivan141 Wrote: [ -> ]Kouki 10k has been done before.. I'm not a big fan of the pinstripe myself but it should end up looking roughly like this:Not a huge fan either but that's what I've got and the speed side is fine being EU kmh spec http://www.blackcatcustom.com/ one more photo at night http://i927.photobucket.com/albums/ad112...021662.jpg im also interested if anyone can made them cheaper.!
02-05-2015, 07:00 PM
(This post was last modified: 02-05-2015 07:00 PM by d3nso.)
Something like this as EU Spec for the right money and I'm in
02-05-2015, 10:53 PM
Producing something like this in acceptable quality is not very easy.. I still need to speak to some acquaintances who are in the graphical business to discuss the options (avoid finding out the hard way what wont work).
02-06-2015, 07:18 AM
Hi.
Just stumbled on the topic about the custom cauges, you were after 10krpm ones ? I had mine custom made by a Company called MoMan. The quality was very good, and if I remember correct the price was good too. Have a look at scandinavia/Finland messages, the last one messages. They are in finnish language, but you can see on the last too pics of the carbon/white cauge pics what they look like. (02-01-2015 05:10 PM)Bean Bandit Wrote: [ -> ](02-01-2015 01:49 PM)Ivan141 Wrote: [ -> ]Kouki 10k has been done before.. I'm not a big fan of the pinstripe myself but it should end up looking roughly like this:Not a huge fan either but that's what I've got and the speed side is fine being EU kmh spec Drive fast, or crash when trying... |
02-28-2015, 04:46 AM
(This post was last modified: 02-28-2015 05:35 AM by harkes.)
Hi Ivan
I would be very interested in a custom gauge. 10K scale with 9k redline and 8500-9000 yellow zone. Also running the IS200 gearbox my speed is off. 100kmh equal 75kmh gps. The rpm obviously need to be recalibrated but I don't care much about the speed. Two quick ideas. Second one would probably be jinxing it |
| EUDM gauge cluster | banpei | 22 | 15,181 |
08-15-2023 10:48 PM Last Post: banpei |
| EUDM cluster revelations | banpei | 1 | 3,466 |
06-23-2023 09:11 AM Last Post: r.ave |
| Water Temperature Instrument not moving - Sender Gauge | Hama86 | 8 | 12,171 |
12-06-2017 06:48 PM Last Post: Bean |
| Custom Dash Cluster | kazi | 14 | 29,380 |
10-24-2017 09:05 PM Last Post: kazi |
| EDM GT-S Cluster, PWR light VSV? | Rascal21 | 1 | 5,839 |
06-25-2017 08:00 PM Last Post: Rascal21 |
![AEU86 AE86 - Analog gauge cluster tech [Image: AEU86 AE86 - Analog gauge cluster tech]](http://www.autosoftsys.com/supra/tachcompare/tachbits.jpg)
![AEU86 AE86 - Analog gauge cluster tech [Image: AEU86 AE86 - Analog gauge cluster tech]](http://i1181.photobucket.com/albums/x423/djflexdex/Toymods/AE86TachoSchematic.jpg)
![AEU86 AE86 - Analog gauge cluster tech [Image: AEU86 AE86 - Analog gauge cluster tech]](https://lh3.googleusercontent.com/-wqe1OV2_db8/VMz4-AvKqZI/AAAAAAAACF4/vfeBJNK3hWg/s582/ae86_zero_milspec.png)
![AEU86 AE86 - Analog gauge cluster tech [Image: AEU86 AE86 - Analog gauge cluster tech]](https://lh4.googleusercontent.com/-e979oCCwaqo/VMz4sHZTQ0I/AAAAAAAACFs/exUofqCB3Is/s582/ae86_zero_altedin_mph.png)
