Rear Half Shaft axles
12-06-2007, 01:24 AM
I have a GT-S LSD differential and i need to replace my right side half shaft because the guy who owned the car before me drifted into a curb., would a SR5 half shaft fit in ? or a zenki ? kouki?
12-06-2007, 01:28 AM
do you have a kouki or zenki lsd?
12-06-2007, 01:33 AM
I dont know ? all I know is on the back of the differential it says LSD and my car is a GTS model.
12-06-2007, 01:36 AM
what year is your car
12-06-2007, 04:21 AM
1986 why?
12-06-2007, 07:44 AM
Zenki = early model
Kouki = late model This means that you properbly need a Kouki axle. But to make sure you'll need to take out an axle and messure how thick it is... Sarcasme is just one of the things I offer Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch |
12-06-2007, 08:49 AM
Rear Half Shaft axles | |||
12-06-2007, 09:38 AM
thanks aussiefan for that info.
I looked at the pictures and my axle is the same as the picture on the right. I'm guessing that there isn't a parts number for a half shaft.. is there? |
12-06-2007, 09:54 AM
you're welcome
there are part numbers for that i can take a look at Toyotas EPC when i'm at home |
12-06-2007, 10:23 AM
And the only place you will get an axle from is another AE86 fitted with a T series rear end, nothing else is a direct swap without substantial machining/welding. S series (I presume SR5's have those in the USA) are different, including at the bearing collar (too narrow).
Play between steering column and intermediate shaft after manual rack sonversion | DaLanZhu | 5 | 5,828 |
Steering shaft issue | Ryo | 15 | 11,465 |
11-19-2018 09:52 AM Last Post: Ivan141 |
Half Shafts Poblem | AlexKTM | 6 | 6,061 |
04-23-2018 04:42 PM Last Post: MIGGZFSU |
Propeller shaft universal joint | kawo | 1 | 3,938 |
05-19-2014 11:05 AM Last Post: Uzelac |
zenki and kouki model rear axles | megabob | 7 | 8,215 |
03-13-2013 08:43 PM Last Post: megabob |
