OST-054: 3 rib with snap
01-10-2019, 01:07 AM
![]() OST-054's owner is "local" (no shipping). The first head he brought to me, back in early December, had seen an "attempt" at changing the squish pads At this time I'd like to STRONGLY recommend that if you "try" to port a head, and you don't know what you are doing... STOP. In the past 3 years I've bought 3 heads that had to be scrapped because of very poor "attempts"..... that runied the casting If you are going to try... just make sure that head isn't sold on.......So my client disassembles his engine to get me his current head... and it too has seen a hand inside it. On this one it wasn't "fatal"..... the roof of the port has seen some "work"... along with a lot of "smoothing" inside the exhaust port. ![]() This type of work (tapering port roof) I try to reserve for ITB equipped heads to try and and match the angle of the ITB adapter. In this case some care was used by the previous "porter" so that this head could be re-used. disassembled, prior to cleaning ![]() This head has been machined once as well ![]() more to come....
Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
01-11-2019, 07:00 PM
what should the head size be if it hasn't been machined before?
01-12-2019, 01:34 AM
(01-11-2019 07:00 PM)kazi Wrote: what should the head size be if it hasn't been machined before? 116mm work begins..... #4 on the left... ![]() Oh... as the title states... this is a 3 rib, and my client manage to find a set of high comp TVIS pistons 13103-16030, the same pistons I used in OST-050. ![]() His short block is being built at a local machine shop - with my technical assistance. more to come.....
01-12-2019, 11:46 PM
oldeskewltoy Wrote:work begins..... #4 on the left... from another forum Wrote:Short turns look beautiful. and #3 and #2 ![]() more to come.....
01-15-2019, 12:08 AM
![]() Intake side finished... on to the exhaust side and the chambers.... more to come....
01-16-2019, 08:10 PM
oldeskewltoy Wrote:on to the exhaust side 3 down so far..... ![]() more to come....
01-18-2019, 02:47 AM
oldeskewltoy Wrote:3 down so far..... and now the exhaust side is done..... ![]() and from a slightly different perspective... Next is getting the chambers deshrouded..... more to come.....
01-18-2019, 08:06 PM
Not sure if I didn't pay enough attention the last many times or did you get a lot faster?
Sent from my MHA-L29 using Tapatalk AE86 ex-daily |
01-22-2019, 07:07 PM
(01-18-2019 08:06 PM)Bean Wrote: Not sure if I didn't pay enough attention the last many times or did you get a lot faster? not really faster.... In this case I waited till I got the head back from the machine shop after cleaning to begin posting. oldeskewltoy Wrote:Next is getting the chambers deshrouded..... simple progression photo.... ![]() and a little before and after before it gets its 3 angle ![]() more to come...
01-28-2019, 07:03 PM
![]() the head is back... briefly... so I can check and set chamber volumes.... ![]() Now it is back @ the machine shop about to get .016" taken off to set the chamber volumes @ 35cc. A 35cc chamber, along with the proper squish should net my client a static compression ratio of about 11.0:1. Mix in a set of Cat cams 252/222 8.5mm lift cams, and this engine should pull (make power) to low/mid 8000s more to come.....
| (Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 3,978 |
| OST-093: My, My, Mystery | oldeskewltoy | 10 | 8,033 |
| (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 5,486 |
| (Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 3,610 |
| (Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 2,914 |
![AEU86 AE86 - OST-054: 3 rib with snap [Image: AEU86 AE86 - OST-054: 3 rib with snap]](http://ost.ebeans.ch/albums/userpics/10005/ost-054.jpg)
If you are going to try... just make sure that head isn't sold on.......![AEU86 AE86 - OST-054: 3 rib with snap [Image: AEU86 AE86 - OST-054: 3 rib with snap]](http://ost.ebeans.ch/albums/userpics/10005/step_removed_prior.jpg)
![AEU86 AE86 - OST-054: 3 rib with snap [Image: AEU86 AE86 - OST-054: 3 rib with snap]](http://ost.ebeans.ch/albums/userpics/10005/disassembled_head_exhaust_view.jpg)
![AEU86 AE86 - OST-054: 3 rib with snap [Image: AEU86 AE86 - OST-054: 3 rib with snap]](http://ost.ebeans.ch/albums/userpics/10005/thickness_before_work.jpg)
![AEU86 AE86 - OST-054: 3 rib with snap [Image: AEU86 AE86 - OST-054: 3 rib with snap]](http://ost.ebeans.ch/albums/userpics/10005/working__4_seats_and_bowls2.jpg)
![AEU86 AE86 - OST-054: 3 rib with snap [Image: AEU86 AE86 - OST-054: 3 rib with snap]](http://ost.ebeans.ch/albums/userpics/10005/pistons_-_old_vs_new.jpg)
![AEU86 AE86 - OST-054: 3 rib with snap [Image: AEU86 AE86 - OST-054: 3 rib with snap]](http://ost.ebeans.ch/albums/userpics/10005/working__3_and__2_bowls_and_seats_2_panel_circled.jpg)
![AEU86 AE86 - OST-054: 3 rib with snap [Image: AEU86 AE86 - OST-054: 3 rib with snap]](http://ost.ebeans.ch/albums/userpics/10005/intake_3_panel~0.jpg)
![AEU86 AE86 - OST-054: 3 rib with snap [Image: AEU86 AE86 - OST-054: 3 rib with snap]](http://ost.ebeans.ch/albums/userpics/10005/exhaust_side_3_down_circled.jpg)
![AEU86 AE86 - OST-054: 3 rib with snap [Image: AEU86 AE86 - OST-054: 3 rib with snap]](http://ost.ebeans.ch/albums/userpics/10005/exhaust_side_4_down_circled.jpg)
![AEU86 AE86 - OST-054: 3 rib with snap [Image: AEU86 AE86 - OST-054: 3 rib with snap]](http://ost.ebeans.ch/albums/userpics/10005/chambers_multipanel_outlined.jpg)
![AEU86 AE86 - OST-054: 3 rib with snap [Image: AEU86 AE86 - OST-054: 3 rib with snap]](http://ost.ebeans.ch/albums/userpics/10005/before_after_2_panel.jpg)
![AEU86 AE86 - OST-054: 3 rib with snap [Image: AEU86 AE86 - OST-054: 3 rib with snap]](http://ost.ebeans.ch/albums/userpics/10005/showing_its_angles.jpg)
![AEU86 AE86 - OST-054: 3 rib with snap [Image: AEU86 AE86 - OST-054: 3 rib with snap]](http://ost.ebeans.ch/albums/userpics/10005/checking_chamber_volumes~0.jpg)
