OST-035: Silver Blaze
10-14-2015, 10:22 PM
working the final port/bowl of this head...
![]() ![]() and now with the head ready to go back and get it's exhaust only 3 angle, and a minimum re-surfacing - .001" more to come....... Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
10-21-2015, 08:41 PM
Back from the machine shop... surface was machined .002", isn't that pretty, and ready to accept a metal gasket.
![]() Now carrying the exhaust 3 angle(bowl closest), and as you can see the intake 3 angle is still good, so I used a tiny bit of lapping paste to get the intake seats and valves mated ![]() Clover lapping paste on left, Permetex/NAPA valve grinding compound on right... think of the Clover as a polish ![]() that polish helped reveal..... a tiny bit more performance may be available with a back cut on the intakes. That is for another day/head. ![]() the red arrow is pointing to the top of the seat-valve contact point, so the dotted green lines represents a bit of room for a simple, clean back cut. Finally, my client asked me if I could do something to better accommodate his use of ARP studs.... ![]() Look back at the first pic in this post to see the bolt hole before..... more to come..... Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
10-21-2015, 10:02 PM
from another forum Wrote:I enjoy reading the detail in your threads but not being an engine builder guy I probably understand less than half of what you're saying...:confused: I use an epoxy filled spark plug with the ground electrode removed. This gives me a consistent measure. Yes - a "colder" plug will often times have a bit more room around the positive electrode, effectively increasing the chambers volume. multiple angle valve seats - Air flowing past with minimal eddy currents. A steep angle on any of these faces and tiny eddy currents can cause poorer flow. I've recently heard about a 7 angle... yes 7 angle valve seats... can't find a pic, but here is a 5 angle.... http://www.d-series.org/forums/attachmen...5angle.jpg now if your machinist has the capability, this is what is often the top of the line for flow past the valve, it is a radius valve job - http://rennlist.com/forums/attachments/9...t-pic3.jpg the only flat surface on there is the small area where the valve contacts the seat, the rest is a radius Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
10-24-2015, 02:11 AM
oldeskewltoy Wrote:another new tool on the way.......... I realized that I needed a new support system to assemble this head... and so now that the port work, the valve job and the machine work are complete, assembly follows....... ![]() the nut driver under the head was my seal installation driver today ![]() The 2nd new tool can be seen supporting the head. so here is the 1st new tool (9/30/2015 post) up close, in "action" ![]() and fitting the last valve.... ![]() assembled.... waiting for its owner.
10-24-2015, 09:08 AM
(This post was last modified: 10-24-2015 09:09 AM by Bean.)
We'll done, one happy person more
AE86 ex-daily |
| Blaze's AE86 | Blaze0010 | 54 | 31,406 |
10-16-2025 02:17 PM Last Post: ZaX |
| (Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 4,634 |
| OST-093: My, My, Mystery | oldeskewltoy | 10 | 9,592 |
| (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 6,449 |
| (Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 4,308 |
![AEU86 AE86 - OST-035: Silver Blaze [Image: AEU86 AE86 - OST-035: Silver Blaze]](http://ost.ebeans.ch/albums/userpics/10005/exhaust_port_4_3_panel_transition.jpg)
![AEU86 AE86 - OST-035: Silver Blaze [Image: AEU86 AE86 - OST-035: Silver Blaze]](http://ost.ebeans.ch/albums/userpics/10005/3_panel_exhaust.jpg)
![AEU86 AE86 - OST-035: Silver Blaze [Image: AEU86 AE86 - OST-035: Silver Blaze]](http://ost.ebeans.ch/albums/userpics/10005/machined__002_inches_-_showing_chambers_and_exhaust_ports_smaller.jpg)
![AEU86 AE86 - OST-035: Silver Blaze [Image: AEU86 AE86 - OST-035: Silver Blaze]](http://ost.ebeans.ch/albums/userpics/10005/showing_3_angles_int_and_exh.jpg)
![AEU86 AE86 - OST-035: Silver Blaze [Image: AEU86 AE86 - OST-035: Silver Blaze]](http://ost.ebeans.ch/albums/userpics/10005/normal_grinding_vs_lapping_-_compounds.jpg)
![AEU86 AE86 - OST-035: Silver Blaze [Image: AEU86 AE86 - OST-035: Silver Blaze]](http://ost.ebeans.ch/albums/userpics/10005/normal_silvertop_intake_valve_showing_capability_for_back_cut.jpg)
![AEU86 AE86 - OST-035: Silver Blaze [Image: AEU86 AE86 - OST-035: Silver Blaze]](http://ost.ebeans.ch/albums/userpics/10005/overbored_oil_feed_hole.jpg)
![AEU86 AE86 - OST-035: Silver Blaze [Image: AEU86 AE86 - OST-035: Silver Blaze]](http://www.jegs.com/images/photos/500/555/555-80725.jpg)
![AEU86 AE86 - OST-035: Silver Blaze [Image: AEU86 AE86 - OST-035: Silver Blaze]](http://ost.ebeans.ch/albums/userpics/10005/head_beginning_assembly.jpg)
![AEU86 AE86 - OST-035: Silver Blaze [Image: AEU86 AE86 - OST-035: Silver Blaze]](http://ost.ebeans.ch/albums/userpics/10005/head_during_assembly.jpg)
![AEU86 AE86 - OST-035: Silver Blaze [Image: AEU86 AE86 - OST-035: Silver Blaze]](http://ost.ebeans.ch/albums/userpics/10005/head_assembly_finished.jpg)
