OST-035: Silver Blaze
10-14-2015, 10:22 PM
working the final port/bowl of this head...
[Image: AEU86 AE86 - OST-035: Silver Blaze]
and now with the head ready to go back and get it's exhaust only 3 angle, and a minimum re-surfacing - .001"
more to come....... Big Grin
Dan -
10-21-2015, 08:41 PM
Back from the machine shop... surface was machined .002", isn't that pretty, and ready to accept a metal gasket.
Now carrying the exhaust 3 angle(bowl closest), and as you can see the intake 3 angle is still good, so I used a tiny bit of lapping paste to get the intake seats and valves mated
Clover lapping paste on left, Permetex/NAPA valve grinding compound on right... think of the Clover as a polish
that polish helped reveal..... a tiny bit more performance may be available with a back cut on the intakes. That is for another day/head.
the red arrow is pointing to the top of the seat-valve contact point, so the dotted green lines represents a bit of room for a simple, clean back cut.
Finally, my client asked me if I could do something to better accommodate his use of ARP studs....
Look back at the first pic in this post to see the bolt hole before.....
more to come..... Big Grin
Dan -
10-21-2015, 10:02 PM
from another forum Wrote:I enjoy reading the detail in your threads but not being an engine builder guy I probably understand less than half of what you're saying...:confused:
What is the purpose/benefit of the multiple angles on the valve seats? Radiusing the openings for better flow?
Does the type of spark plug used during chamber volume measurement vary the reading? Or is something else used to plug the hole during measurement?
I use an epoxy filled spark plug with the ground electrode removed. This gives me a consistent measure. Yes - a "colder" plug will often times have a bit more room around the positive electrode, effectively increasing the chambers volume.
multiple angle valve seats - Air flowing past with minimal eddy currents. A steep angle on any of these faces and tiny eddy currents can cause poorer flow.
I've recently heard about a 7 angle... yes 7 angle valve seats... can't find a pic, but here is a 5 angle.... http://www.d-series.org/forums/attachmen...5angle.jpg
now if your machinist has the capability, this is what is often the top of the line for flow past the valve, it is a radius valve job - http://rennlist.com/forums/attachments/9...t-pic3.jpg the only flat surface on there is the small area where the valve contacts the seat, the rest is a radius
Dan -
10-24-2015, 02:11 AM
oldeskewltoy Wrote:another new tool on the way..........
I realized that I needed a new support system to assemble this head...
and so now that the port work, the valve job and the machine work are complete, assembly follows.......
the nut driver under the head was my seal installation driver today Wink
The 2nd new tool can be seen supporting the head.
so here is the 1st new tool (9/30/2015 post) up close, in "action"
and fitting the last valve....
assembled.... waiting for its owner.
Dan -
10-24-2015, 09:08 AM (This post was last modified: 10-24-2015 09:09 AM by Bean.)
We'll done, one happy person more Hurray!
  Blaze's AE86 Blaze0010 53 16,459 09-08-2025 03:01 PM
Last Post: The Doctor
  (Catching up) OST-086 MM: Built for Mario oldeskewltoy 2 3,239 10-28-2022 08:23 AM
Last Post: decryphe
  OST-093: My, My, Mystery oldeskewltoy 10 6,567 09-18-2022 02:19 AM
  (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams oldeskewltoy 5 4,497 09-09-2022 09:07 PM
Last Post: Vaptor
  (Catching up...) OST-083: Salvage operation oldeskewltoy 2 2,879 07-11-2022 08:32 PM
