OST-019: Collaboration
10-11-2012, 02:28 AM
oldeskewltoy Wrote:So the head will likely be @ the shop for closer to 2 weeks so the parts can arrive from Toyota's Cincinnati depot
Another soap opera...... LOOOONG story short... Supertech guides on the intake, and OEM O/S guides for the exhaust. Oh... and it is about 2 weeks :thumbsdown:
Well, with the head back here, the last bit of work is now in order. The head has large crescent shaped machining marks left over in the head from production. These machining marks will be smoothed out into the surrounding area of the chamber. This will remove a sharp edged protrusion in the chamber, allowing the chamber to support more compression without pre-ignition.
[Image: AEU86 AE86 - OST-019: Collaboration]
Also note the 3 angle valve job.... On the 4AGE, there are different angles for intake and exhaust.... and they can be seen in this view
I had the head cut .015" estimating the amount of material I'll be removing to de-shroud the chambers. I set up the burette
I measured all the chambers, their volume ranges between 34.7cc, and 34.8cc. The chamber below is the one measuring 34.7cc.
I use the bottom of the meniscus for my measurement.
So, that "gives" me 1.2 to 1.3cc of volume I can add to these chambers volume (to get them back to stock 36cc) while removing the machining marks.
More to come...... Big Grin
Dan -
10-12-2012, 01:10 AM
oldeskewltoy Wrote:So, that "gives" me 1.2 to 1.3cc of volume I can add to these chambers volume (to get them back to stock 36cc) while removing the machining marks.
Chamber #3... The chambers are now de-shrouded, and chamber volume is back up to 36cc.... same as stock
The above chamber can now(bottom panel) withstand considerably more compression without pre-ignition, then it could when I started(top panel)
Dan -
10-13-2012, 08:21 AM
Thumbs up!
SR Team
BURN THE RUBER NOT YOUR SOUL!
  OST-125: Building a big valve 5AGTTE (yes, twin turbocharged) oldeskewltoy 14 2,050 11-09-2026 09:58 PM
  (Catching up) OST-086 MM: Built for Mario oldeskewltoy 2 4,896 10-28-2022 08:23 AM
Last Post: decryphe
  OST-093: My, My, Mystery oldeskewltoy 10 10,247 09-18-2022 02:19 AM
  (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams oldeskewltoy 5 6,881 09-09-2022 09:07 PM
Last Post: Vaptor
  (Catching up...) OST-083: Salvage operation oldeskewltoy 2 4,635 07-11-2022 08:32 PM
