Hydraulic handbrake
10-13-2006, 07:50 PM
Hydraulic handbrake
i have one of hese waiting to go into my ae86 but ive never fitted one before, could some explain to me where to connect to and what type of fittings to use, i have copper brake pipe also.
10-13-2006, 09:51 PM
Hydraulic handbrake
Hope this can help:
http://www.aeu86.org/Writeup/Brakesystem...index.html
It doesn't say anything about the fittings though. Undecided
[Image: AEU86 AE86 - Hydraulic handbrake]
10-14-2006, 07:31 PM
Hydraulic handbrake
i kinda wanted something a bit more informative with exact locations specified or shown but thanks anyway, anyone else help out.
10-14-2006, 08:55 PM
Hydraulic handbrake
Here is a picture, this is a way the pipes go
http://s33.photobucket.com/albums/d61/Kl...h=imgAnch1
http://s33.photobucket.com/albums/d61/Kl...h=imgAnch2
cylinder "bolts" are 7/16" UNF and 3/8" UNF.
10-15-2006, 12:02 PM
Hydraulic handbrake
Here is a pic from my TRD Corolla levin Sprinter Trueno Special Edition Bible.
Maybe this can help you.
I also got a hydro handbrake that i still need to put in the car.
I think this is the best way to do it.
Toyota MR2 2.0 16V Gen3 Turbo
Toyota MR2 1.6 16V
10-15-2006, 09:59 PM
Hydraulic handbrake
ehm...dual master cilinders isnt exactly a simple install to do..
10-16-2006, 08:55 AM
Hydraulic handbrake
Added pics as attachments. Wink
10-16-2006, 10:46 AM
Hydraulic handbrake
Also I see some kind of one-way dual valve in rear brake hydraulic circuit (maybe this way interference between hand and pedal braking is avoided).
What if you just add another set of rear calipers + independent hydraulic circuit for hand brake ?
10-16-2006, 12:41 PM
Hydraulic handbrake
Keep the existing cable set up & just buy a kit from any rally shop, which includes the cylinder, this is better for mots as you need a physical cable attachment
10-16-2006, 01:52 PM
Hydraulic handbrake
jamiemirror Wrote:Also I see some kind of one-way dual valve in rear brake hydraulic circuit (maybe this way interference between hand and pedal braking is avoided).
I'we heard on DIY hidraulic handbrake it likes to overflow the master cilinder when you pull the handbrake.
Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62
  Handbrake adjustment discs? DMC 8 5,936 03-10-2024 08:08 PM
Last Post: DMC
  Hydraulic handbrake with stock rear brakes Dino86 11 21,991 07-11-2014 08:33 PM
Last Post: Dino86
  How to make the handbrake more effective? heshan 8 15,488 04-27-2011 03:43 PM
Last Post: heshan
  Handbrake issues heshan 4 7,947 12-13-2010 07:15 AM
Last Post: assassin10000
  Hydraulic Clutch tomatinaton 8 11,347 05-09-2009 03:21 AM
Last Post: |BUDA|
