How does the 4age AFM system work?
11-14-2012, 09:02 AM
Guys, I'd like to know a bit about our AFM unit and how it works.
Also what impact does the screw adjustment have on the overall vehicle running? Thanks, Heshan. Cheated on my いたずらな女の子 and now I can't get enough of her.. |
11-14-2012, 12:06 PM
i think this is what you want to know,not sure
![]() https://www.youtube.com/watch?v=uNaJSAej...re=g-all-u He has some other very interesting video's as well. |
11-14-2012, 03:56 PM
This was very helpful..
Does anyone know the standard setting in AFM? Right now I'm having a high CO rating in my exhaust and getting very risky with my emissions test.. Want to know whether its got anything to do with my AFM.. Will be doing a tune up as well.. Cheated on my いたずらな女の子 and now I can't get enough of her.. |
11-14-2012, 05:32 PM
do you have a CAT or not?
AE86 ex-daily |
11-14-2012, 06:06 PM
I do.. How do I check whether its doing its job?
11-14-2012, 08:15 PM
not entirely sure anymore as I haven't had a CAT for 5+ years and the brain isn't what it used to be. If I remember correctly, if only CO is out then it's most likely the CAT - was the car properly warmed up? a hot CAT works way better than a cold one.
AE86 ex-daily |
11-14-2012, 08:17 PM
Yes it was.. It was in running temp for about 15 mins..
So a tune up isn't exactly what's going to resolve this you think? Cheated on my いたずらな女の子 and now I can't get enough of her.. |
11-14-2012, 08:49 PM
if you say running temp for 15min - do you mean just idling? if yes that's not going to cut it with an old cat. go for a spirited drive for 30min and then straight for a measurement and see if anything changed.
AE86 ex-daily |
11-15-2012, 04:19 AM
I did a spirited drive for 15 mins..
Probably I should change the cat to a newer one anyway.. Cheated on my いたずらな女の子 and now I can't get enough of her.. |
11-15-2012, 05:57 PM
I assume your timing is right, TPS set correctly and no leaks in air supply or exhaust... also no fault codes from the ECU. If you have a CAT you also have a lambda sensor which could be out of calibration due to wear or covered in residues
AE86 ex-daily |
| AFM to Map Conversion | ps13michi | 3 | 6,721 |
| Stack display system, need help | Jimmi The Kid | 1 | 7,215 |
01-15-2017 10:52 PM Last Post: Ivan141 |
| Anyone know what this plug does? | Super86 | 3 | 9,069 |
08-01-2016 03:57 PM Last Post: Nakilad |
| How seatbelt rails work? | FanIsHere | 2 | 6,909 |
05-18-2016 09:52 AM Last Post: Bean |
| Bluetop AFM with air filter | izanagi | 4 | 10,015 |
04-29-2016 07:29 PM Last Post: oldeskewltoy |
