01-13-2005, 09:15 PM
Post: #61
The weight difference between 40 and 42 mm cranks is ~0.7 kg.
The most important advantages of later 4AGE's (esp. non-tvis) are higher CR and velocity (due to smaller intake ports). I personaly think that NA will be better with bluetop bottom&non-tvis head, turbo will take benefits of bluetop head and non-tvis bottom end (very similar to 4AGZE one!).
PS: non-tvis internals include 7-ribs, oil squirters, massive rods, 42/20mm crank/pin, can work with 4AGZE pistons.
01-15-2005, 09:26 PM
Post: #62
Just a very quick update: My engine is finally running. No problems whatsoever Thumbs up! I'm getting the car back on Monday or Tuesday at the latest!
Pics on Monday!
01-16-2005, 12:28 AM
Post: #63
Congratulations dorito. Glad to hear. Smile
01-16-2005, 11:47 AM
Post: #64
Dorito way to go mate!
01-16-2005, 03:58 PM
Post: #65
Yay! Hurray!
How long did it take you? Atleast 2 months I'd say. Smile
[Image: AEU86 AE86 - Greek AE86 restoration/modification (pics)]
01-16-2005, 11:57 PM
Post: #66
Bravo dorito kai kales, grigores kai asfaleis boltes!
I will start repairing mine on Wednesday.
Hope we'll meet someday...
ΓΙΩΡΓΟΣ
01-17-2005, 11:17 AM
Post: #67
Thank you guys! It has been a [u:4ddc69bb09]very[/u:4ddc69bb09] stressed out weekend. I can't wait to sit behind the wheel and start breaking it in.
Now on to the details. The T3 short-shift is in place. Installation is piece-of-cake and it feels a bit strange. The throw is indeed very much reduced, but it will take some practice to get used to.
The exhaust manifold has been drilled and fitted with a lambda sensor (needed by AE92 ECU).
The engine gave us a bit of trouble, but it was fixed fianally. The starter was turning, but it just wouldn't start.
First we checked the spark plug wires. They were live.
Then we checked the fuel. The injectors were spraying allright.
Then we checked compression. Compression was good.
Then we noticed that in-cam and ex-cam lobes were pointing at the same direction for a given cylinder. Duuuuh!
Apparently the mechanic had started rebuilding this particular motor sometime in the past, had gone as far as removing the cams and then aborted the project and put it back together hastily. As a result, when he marked the cam gears to disassemble it for me, the cam position was all f**ked up and he didn't notice when putting it back together.
So basically in and ex valves were opening upp at the same time, loosing compression and letting the mixture go straight out the exhaust.
But we fixed that too and it started 1st time.
So now, all is in place, except some panels in the car and minor things to be strapped down in the engine bay. I should be getting it back today or tomorrow. Hurray! Will post first pics on the road when I have them.
01-17-2005, 11:38 AM
Post: #68
Damn man.Stupid mechanics.
Can i come with you tommorow to take the hachi?
[Image: AEU86 AE86 - Greek AE86 restoration/modification (pics)] http://www.jdmbits.com
01-17-2005, 11:41 AM
Post: #69
Shure dude! I'll let you know.
01-17-2005, 03:51 PM
Post: #70
Thnx stupi-rito86.
That's your new nick name now.
No certain reason for it, just that you write "shure" instead of "sure".
But then I think I make even more mistakes myself.
CAll me tommorow ok?
  Full restoration... Blade1988 64 101,377 07-17-2016 11:53 AM
Last Post: McGlinchey
  Another danish restoration Duze 61 89,308 03-20-2016 08:58 AM
Last Post: Duze
  '84 ae86 restoration project HybriD07 19 31,154 10-13-2014 09:20 PM
Last Post: HybriD07
  TOYOTA COROLLA Ke70 - Restoration project cke70 34 63,668 07-02-2014 10:12 PM
Last Post: cke70
  Black Limited restoration slpery86 6 12,174 12-17-2013 09:22 PM
