Digital Dash
02-20-2013, 04:28 PM
Post: #91
Digital Dash
that's my same problem. the tachometer also doesn't work. i connected the output wire going to tacho from coil, to the Pin2 (Black, brown dots) at the left plug of the digital cluster. it does not move.
btw, mine is KE70, not AE86 so I what I really need is the pinout. do I have to do more beside connecting the tacho- to pinout2? |
02-20-2013, 06:03 PM
Post: #92
Digital Dash
I have all the information at home.....
If you guys need i can make a full scheme of a LHD pinout convertion. Regards |
02-20-2013, 06:19 PM
Post: #93
Digital Dash
i never knew the illimination could work with a digital dashboard?
maybe i did something wrong or so. i can take some pictures of mine if i get the cable loom back. |
02-20-2013, 06:37 PM
Post: #94
Digital Dash
thank you pack.. I'll be waiting for your post again..
cheers
02-20-2013, 09:52 PM
Post: #95
Digital Dash
I really tought i had the notes on my desk at home... But it's at work....
Damn... i could have posted that today for you guys! Well... I have everything described, and can take pictures of my notes to build a nice DIY here. Gimme tomorrow morning and i'll post everything! Thansk |
02-21-2013, 11:17 AM
Post: #96
Digital Dash
yeah its ok. i followed what's written inthe excel file, but for me, tachometer is not working though. thanks
02-21-2013, 08:37 PM
Post: #97
Digital Dash
choyr Wrote:yeah its ok. i followed what's written inthe excel file, but for me, tachometer is not working though. thanksIf tachometer does not work even after so could be faulty IC T2685A. It is used in analog tachometer http://www.aliexpress.com/item/T2685A-Lo...11843.html |
02-22-2013, 07:44 AM
Post: #98
Digital Dash
[quote="ilker_ae86"]
*** I found tachometer + and -. My tacho works. I'm not planning to use fuel gauge. but my fuel gauge illumination and water temp illumination did't work. Are they need different + and earth. maybe because of this tachometer+.. which pinout is this? I'll try to check the IC of the analogue tachometer of my old cluster, it was working then. |
02-22-2013, 12:38 PM
Post: #99
Digital Dash
I have all the information on my notes.... The problem was that the tacho was not working following the schemes on the web.
So, i've found some new schemes and made my tacho work properly. I also have to get a led light working and have to disassemble my dash. Maybe Saturday afternoon. If i'll get it done, i will post some pictures of my wiring! Also i will post a picture of my schemes.... Legend: Risca - Stripe Preto - Black Branco - White Verde - Green Amarelo - Yellow Azul - Blue Castanho - Brown ![]() The tacho was wired at the end... so i'll have to dig again for info! Regards |
02-22-2013, 09:58 PM
Post: #100
Digital Dash
choyr Wrote:[quote="ilker_ae86"]Defects will probably in digital dash. Not necessary, others + and the earth It is only + for digital and control lights |
| Digital speedometer on stock dashboard | FanIsHere | 0 | 3,511 |
| Dash Waning Lights | pack | 7 | 8,369 |
10-06-2021 01:00 PM Last Post: pack |
| Trueno Digital dash kph to mph | Bojack | 3 | 10,160 |
11-21-2018 12:27 AM Last Post: kazi |
| Custom Dash Cluster | kazi | 14 | 29,390 |
10-24-2017 09:05 PM Last Post: kazi |
| Dash Lights | kazi | 3 | 8,104 |
09-12-2017 10:04 PM Last Post: kazi |
cheers
![AEU86 AE86 - Digital Dash [Image: AEU86 AE86 - Digital Dash]](http://i46.tinypic.com/105xsvo.jpg)
