Digital Dash
02-14-2021, 07:54 AM
Post: #181
Digital Dash
(02-05-2021 05:43 AM)mister86 Wrote: ...not sure how to get the digital dash to work now (worked previously with the stock ecu). Are you saying that you had the digital dash including tacho working when it was connected to the OEM Toyota ECU in a non-factory digital dash car ? Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
02-14-2021, 04:20 PM
Post: #182
Digital Dash
(02-14-2021 07:54 AM)jondee86 Wrote:(02-05-2021 05:43 AM)mister86 Wrote: ...not sure how to get the digital dash to work now (worked previously with the stock ecu). That is correct. |
02-14-2021, 09:41 PM
Post: #183
Digital Dash
Did you do the dash conversion, or was it already in the car when you bought it ?
02-14-2021, 09:46 PM
Post: #184
Digital Dash
(02-14-2021 09:41 PM)jondee86 Wrote: Did you do the dash conversion, or was it already in the car when you bought it ? I did the dash conversion with help from Ronnie on the Club4AG forums. I bought the digital fuel sender, oil pressure sensor and cooling sensor, and then he modified the digital gauge cluster to be plug n play. |
02-15-2021, 03:45 AM
Post: #185
Digital Dash
And by "plug-n-play" you mean that you used the same dash harness that was used for
the analog dash and just changed the sensor plugs for the fuel, oil and coolant sensors ? No change to the igniter ? Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
02-15-2021, 03:49 AM
Post: #186
Digital Dash
(02-15-2021 03:45 AM)jondee86 Wrote: And by "plug-n-play" you mean that you used the same dash harness that was used for Correct on the sensors. And yes. Same dash harness with a few changes to how the analog vs digital dash was wired since it’s slightly different. And got rid of the igniter to use with my aftermarket ECU and coil on plug. |
02-15-2021, 05:10 AM
Post: #187
Digital Dash
Do you still have the igniter that worked with the digital dash before you changed
to the LINK and COP's ? Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
01-07-2023, 10:32 PM
Post: #188
Digital Dash
Anyone tried this out with a Beams engine?
exact if oil pressure sensor and water temp sensor working digital? Any one tried this out for the Fuel sender conversion maybe: https://spiyda.com/fuel-gauge-wizard-mk3.html |
01-08-2023, 10:44 PM
(This post was last modified: 01-08-2023 10:44 PM by banpei.)
Post: #189
Digital Dash
A few years ago I planned to do a conversion using an arduino:
http://www.aeu86.org/forum/Thread-Digita...#pid174731 I never did this as shortly afterwards the AE86 was put into storage. The Gauge Wizard seems to solve the exact same problem in a similar way, but then more universal. What I like is that it's also able to calibrate. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
04-10-2024, 03:28 PM
(This post was last modified: 04-10-2024 11:00 PM by banpei.)
Post: #190
Digital Dash
Today this arrived:
I've ordered the Spiyda Gauge Wizard. A few weeks ago I already bought a NOS analogue fuel sender for the Carina. It has the exact same resistance on low and high fuel levels as the AE86 analogue sender, so it will be a good test mule for the Spyda. In a few weeks time I'll have some spare time on my hands and try to test if the Gauge Wizard can be used to convert the resistance to voltage. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
| Digital speedometer on stock dashboard | FanIsHere | 0 | 2,799 |
| Dash Waning Lights | pack | 7 | 6,940 |
10-06-2021 01:00 PM Last Post: pack |
| Trueno Digital dash kph to mph | Bojack | 3 | 9,062 |
11-21-2018 12:27 AM Last Post: kazi |
| Custom Dash Cluster | kazi | 14 | 26,539 |
10-24-2017 09:05 PM Last Post: kazi |
| Dash Lights | kazi | 3 | 7,303 |
09-12-2017 10:04 PM Last Post: kazi |
![AEU86 AE86 - Digital Dash [Image: AEU86 AE86 - Digital Dash]](https://www.aeu86.org/sticker-banner-468.gif)
