Axle/wheel hop?
09-08-2007, 10:29 PM
Axle/wheel hop?
I am experiencing quite a lot of axle/wheel hop when doing burnouts/donuts.
(had this also before the cusco lsd) Like the whole rear axle start to shake and jump. Tried setting my shocks soft/hard...no difference. Also tried different tires...still there. I read somewhere that traction brackets seem to help this problem. This are the mods on the rear axle: TRD 6k springs Tokico HTS schoks Cusco 2way lsd Everything else is stock. Got prothane bushings here for the 4links and getting a panhard rod soon. But I was wondering if anybody knew where the problem lies exactly. |
09-08-2007, 11:48 PM
Axle/wheel hop?
Lateral rod bushing need replacing, 100%, I see you have a prothane kit which will solve this.
09-09-2007, 06:41 AM
Axle/wheel hop?
New bushings. The old ones are so bad they are binding and loading/unloading under acceleration causing wheel hop.
Traction brackets will also help a great deal by forcing the rear end to 'plant' the tires after correcting your suspension geometry from being lowered. So, do both ![]() Andrew |
09-10-2007, 12:50 PM
Axle/wheel hop?
Traction brackets will INCREASE wheel hop (suspension basics).
09-10-2007, 01:31 PM
Axle/wheel hop?
jamiemirror Wrote:Traction brackets will INCREASE wheel hop (suspension basics). How so Jamie? |
09-10-2007, 01:46 PM
Axle/wheel hop?
Have it explained on paper, need to make pics and attach here.
![]() More anti-squat --> more brake wheel hop. http://www.raceglides.com.au/TechInfo.htm Interesting reading btw. |
09-10-2007, 06:18 PM
Axle/wheel hop?
Seems to concur with most reviews I've seen of traction brackets.. Tsuchiya himself likes his car better without them too.
09-10-2007, 06:19 PM
Axle/wheel hop?
Thanks for the replies guys. Going to try the new bushings and adjustable rod first and see if it helps.
@Jamie, if that is the case then I shouldn't have any wheelhop since my 4link bars are pointing up like in the first drawing. But I think I'll get some cheap traction brackets in a month or so to and see what happens. ![]() And are the rca's ready? I pm'ed you about them. Trying to get my car in a decent shape because my suspension geometry is all over the place... haha
09-10-2007, 09:11 PM
Axle/wheel hop?
Pics from the book (very poor quality):
09-11-2007, 07:45 AM
Axle/wheel hop?
the books and URLs are about braking wheel hop. isnt that opposite of acceleration??
rust in piece ricing team. |
| Spare wheel & spare wheel carrier | ondafly | 6 | 2,188 |
01-19-2026 01:00 PM Last Post: ondafly |
| AE86 rear axle weight | megabob | 11 | 26,268 |
| Axle width | totta Crolla | 1 | 3,576 |
| Rear axle options | Dino86 | 13 | 20,837 |
| Rebuild rear disc brakes toyota crown ms112 axle | bozu | 0 | 5,473 |
![AEU86 AE86 - Axle/wheel hop? [Image: AEU86 AE86 - Axle/wheel hop?]](http://www.desertrides.com/reference/images/terms/anti-squat.gif)
