Rear axle options
01-05-2018, 01:38 AM
Rear axle options
modception make a modified pajero axle for the AE86, but it will cost you more than 1200€ :/
you can get it in 4.875 (so close to your target of 5:1, and even shorter CWP for pajero are pretty cheap anyway) http://www.modception.com/products/ae86/...axle-build (They also sell a kit of brackets so you could also make your own , but that not "bolt on" anymore) |
01-06-2018, 02:25 PM
Rear axle options
i would go for the weir spool, way lighter, cheap and strong than a oem welded open diff
01-06-2018, 04:01 PM
Rear axle options
weir spool require their axles and that doesn't solve the shorter ratio problem (6.7" CWP are still pretty expensive and somewhat fragile)
01-08-2018, 10:19 PM
(This post was last modified: 01-08-2018 10:21 PM by ditn.)
Rear axle options
(01-04-2018 10:20 AM)Dino86 Wrote: [ -> ]@Ditn: If you have another address where I could find similar setup as yours that would be great.... or sell me yours Not selling mine I know he has a second one but its alot better than mine even with big ap brakes etc. But it costs alot of €€ Cheapest solution is probably a volvo 2.. rear axle with a dana?/quaife lsd |
| Bigger brake master cylinder options | Koen | 10 | 4,046 |
01-08-2026 03:12 PM Last Post: r.ave |
| AE86 rear axle weight | megabob | 11 | 26,308 |
| Axle width | totta Crolla | 1 | 3,598 |
| ITB filter options | mister86 | 1 | 5,610 |
| AE86 starter options | max_ae86 | 12 | 39,260 |
