Aftermarket or used oil cooler ?
07-14-2006, 12:54 PM
My oil cooler seems to be leaking.
Before deciding to replace it I have to check if only the hoses are leaking, but I doubt...
Anyway, I'd like to know if there are aftermarket (new) oil coolers available and who produces them.
If there are no aftermarket ones, I'll have to go for used one...
Regards
Andrej
Regards
Andrej
07-14-2006, 12:59 PM
AE86 oem cooler is bad and small. RX7 FC one is usual upgrade ( MuX? ).
You can use some bike coolers or go aftermarket.
I have felx-a-lite cooler on my nissan.
With ae86 its simple to do upgrade, only replace the cooler and don't have to mess with sandwich plates.
BR
ZaX
07-14-2006, 01:02 PM
Nopes, you need RX7 SA cooler, thats the 79 - 85 model range. Its an almost direct fit for the hachi but I don't know if RX7's were sold where you live so..
07-14-2006, 01:52 PM
Finding rx7 for spares in my country is almost impossible Sad
If I find an aftermarket one, I'll be satisfied with it, as I don't need a performance one. If there's no aftermarket one, I'll have to buy a performance one.
But I had a look at Nissens and NRF, who are making aftermarket radiators and oilcoolers, but they don't have any oilcoolers listed for Toyota Sad
So I'm wondering if there is any other manufacturer which makes aftermarket oil coolers.
Regards
Andrej
Regards
Andrej
07-14-2006, 02:56 PM
"Moroso" ?
07-14-2006, 03:01 PM
Mocal makes very nice oil coolers - we had one of those on our first AE82 race car and used the "sandwich plate" from an AE86.
07-14-2006, 07:00 PM
You can use oil cooler from Opel Omega Diesel
84' AE86 Levin
96' 500HP WRX, powered by landikar
[Image: AEU86 AE86 - Aftermarket or used oil cooler ?]
07-16-2006, 09:41 PM
or hyundai santa fe
Philip
07-16-2006, 09:47 PM
Just realized I mixed up normal cooler and oil cooler...Smile
No idea what would be a good oil cooler replacement for the hachi.
07-17-2006, 07:17 AM
Tnx for replys Smile
During weekend I found the leaking hole - there's a hole where the lower hose is attached to cooler and the hose is moving Sad
So I tried to use a little bit of high-temp silicone to stop leaking, but bad luck- the oil started leaking more and now my hachi isn't drivable.
I've found someone who repairs radiators, in the next days he'll inspect my radiator and we'll see if it can be repaired...
Regards
Andrej
  Mocal oil cooler & sandwitch plate ordered Gtsi-R 48 65,004 11-18-2022 02:19 PM
Last Post: FanIsHere
  Oil cooler totta Crolla 0 2,209 07-25-2021 03:25 PM
Last Post: totta Crolla
  Aftermarket / Additional Foglights decryphe 6 11,724 07-08-2017 08:45 AM
  Oil cooler kit izanagi 7 10,267 09-20-2016 11:13 AM
Last Post: harkes
  Permanent oil cooler vs thermostat Lt86 19 24,471 03-28-2015 06:54 PM
Last Post: Lt86
