Shims 20V Blacktop
12-23-2017, 05:23 PM (This post was last modified: 12-23-2017 05:56 PM by CHOPKIN2.)
Shims 20V Blacktop
I am new to this. I am pretty sure I am missing shim parts. The attached photo is all I got when I took them off. All I got was the small little disc plates.
Based on what I saw on the TODA website I am missing two pieces. Am I correct?
The forth picture shows someone's shims which look complete compared to mine.
12-23-2017, 06:41 PM
Shims 20V Blacktop
it looks like your shims are inside your buckets. use a pair of needle nose pliers and see if that center bit comes off.
Dan -
12-23-2017, 08:32 PM
Shims 20V Blacktop
(12-23-2017 06:41 PM)oldeskewltoy Wrote:  it looks like your shims are inside your buckets. use a pair of needle nose pliers and see if that center bit comes off.
Any advice on the AGK cams in my other post?
12-23-2017, 11:07 PM
Shims 20V Blacktop
no idea.... sorry
Dan -
  Improve 20V Blacktop cooling pack 0 717 06-07-2023 01:18 PM
Last Post: pack
  stock injector deadtime for 4age 20v silvertop/blacktop injector ditn 1 5,514 02-20-2016 11:48 AM
  Comp. Test - 20v Blacktop hachirokkos 2 4,440 01-10-2016 02:30 AM
Last Post: hachirokkos
  20v blacktop swap bogging znull 7 9,548 09-29-2015 03:57 PM
Last Post: znull
  20V blacktop. what kind off ecu??? slowboy2 11 12,530 07-17-2015 07:01 PM
Last Post: jdm86gtz
