Shims 20V Blacktop
12-23-2017, 05:23 PM
(This post was last modified: 12-23-2017 05:56 PM by CHOPKIN2.)
Shims 20V Blacktop
I am new to this. I am pretty sure I am missing shim parts. The attached photo is all I got when I took them off. All I got was the small little disc plates.
Based on what I saw on the TODA website I am missing two pieces. Am I correct? The forth picture shows someone's shims which look complete compared to mine. |
12-23-2017, 06:41 PM
Shims 20V Blacktop
it looks like your shims are inside your buckets. use a pair of needle nose pliers and see if that center bit comes off.
12-23-2017, 08:32 PM
Shims 20V Blacktop | |||
12-23-2017, 11:07 PM
Shims 20V Blacktop
(12-23-2017 08:32 PM)CHOPKIN2 Wrote:(12-23-2017 06:41 PM)oldeskewltoy Wrote: it looks like your shims are inside your buckets. use a pair of needle nose pliers and see if that center bit comes off. no idea.... sorry Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
Improve 20V Blacktop cooling | pack | 0 | 717 |
06-07-2023 01:18 PM Last Post: pack |
stock injector deadtime for 4age 20v silvertop/blacktop injector | ditn | 1 | 5,514 |
Comp. Test - 20v Blacktop | hachirokkos | 2 | 4,441 |
01-10-2016 02:30 AM Last Post: hachirokkos |
20v blacktop swap bogging | znull | 7 | 9,551 |
09-29-2015 03:57 PM Last Post: znull |
20V blacktop. what kind off ecu??? | slowboy2 | 11 | 12,530 |
07-17-2015 07:01 PM Last Post: jdm86gtz |
