OST's E and R&D
05-11-2014, 06:36 PM
OST's E and R&D
Been doing a bit of experimenting (while waiting for the burette to arrive to replace the broken one from OST-026)
Later today I'll be removing the pours of OST-026's 1st 2 exhaust ports. Once that is done, I'll fit the valves into OST-026 and pour the chamber. While I do that I'll be pouring the exhaust port from the untouched head.... So... I guess.... more to come.... oldeskewltoy Wrote:Later today I'll be removing the pours of OST-026's 1st 2 exhaust ports. Once that is done, I'll fit the valves into OST-026 and pour the chamber. While I do that I'll be pouring the exhaust port from the untouched head.... First the clay is removed, and the valves come out.... Next I use a cork screw.... gradually working it free.... and viola...... The chamber of OST-026 was also poured... and so was the exhaust port of the untouched head more to come...... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
05-11-2014, 08:15 PM
OST's E and R&D
Nice way to compare your job with the original!
1982 - TA60 Carina 4dr sedan - fun cruiser 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
05-11-2014, 10:24 PM
OST's E and R&D
Good work, I think Jeff did something similar quiet some time back.
Sent from my Nexus 4 using Tapatalk AE86 ex-daily |
05-12-2014, 05:49 PM
(This post was last modified: 05-12-2014 06:00 PM by oldeskewltoy.)
OST's E and R&D
from another forum Wrote:Interesting... will you make molds/castings of each head you do work on starting with this one? The supplies, and the time involved don't make it economically feasible to just add it ... BUT I am thinking of offering this as an additional service, for a fee (05-11-2014 10:24 PM)Bean Bandit Wrote: Good work, I think Jeff did something similar quiet some time back. Jeff was doing the 20V intake ports... I'm not sure, but I don't know if he ever did any exhaust bowls/ports (05-11-2014 08:15 PM)banpei Wrote: Nice way to compare your job with the original! Thanks... speaking about comparing the two.... The first thing I can tell you... the original exhaust is, without a doubt, a VERY good port. When I say I gain 3-10hp with my work... This port would lend itself to the lower side of my claim. WHY? The shape of the original port (bowls) shows a decent casting at both the short, and long radius's. They flow smoothly with little disruption. When I came across a head with nasty bowls, I'll cast it and post it, but for now you'll have to trust me... this original is pretty good. So where do I gain 3, to lets say 5 hp in this head? Part of it is in matching the valve seat to the bowl.... but the original design has a slight flaw........ It's "Y" shaped.... so the majority of where I improve the exhaust bowls and ports... even in a good casting... is where the bowls blend into the port...... I turn the "Y"... into a "V"... Less energy to navigate a straight port then one with a kink from another forum Wrote:Any way we could see a atlantic ported head, chamber and ports. I can ask Loynings... but I have a feeling they don't like to reveal as much as I'm willing too.... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
05-12-2014, 08:50 PM
OST's E and R&D
Exactly what I was aiming at...
Nice job on the porting! 1982 - TA60 Carina 4dr sedan - fun cruiser 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
lowering - adj. panhard rod & rca's & panhard bushin | Apolan | 8 | 6,783 |
05-24-2009 10:20 AM Last Post: Apolan |
Is this diff whine and r&p or drive shaft bearing proble | oli | 60 | 46,794 |
10-31-2006 05:57 PM Last Post: oli |
Tokiko Hp & Eibach & Cusco 1.5 RS & koni Sport | Abe | 8 | 6,204 |
05-17-2006 04:30 PM Last Post: Abe |
