Levin Top Speed :)
06-02-2006, 06:41 PM
Levin Top Speed :)
4 A engine no tune Thumbs up!
http://rapidshare.de/files/22030363/Levi...d.avi.html
06-02-2006, 07:41 PM
Levin Top Speed :)
I guess you are using the same gearbox as 4AGE thatswhy the final gear ratio is a bit short to reach higher speeds.
You can easily check your top speed from this diagram:
"..el camino's aren't supposed to make sense, craziness is what makes the world go around." - Car & Driver, 1984
06-03-2006, 07:17 PM
Levin Top Speed :)
El_Camino
Where do you have that diagram from?
I have measured my speed in the hachi, to 198km/h@7270rpm in 5. gear with gps and Apexi SAF-C.
06-06-2006, 10:50 AM
Levin Top Speed :)
Knudsen, this depends also from the tire diameter - I calculated it with my tires - 195/60/14. The final ratio is 4.1, and the gears as follows - 3,587, 2,022, 1,384, 1,000, 0,861
This is a japanese Excel file I have found I partly translated in English.
  drifting extract from Top Gear TV programme UK Stig 2 5,986 08-02-2007 01:10 AM
Last Post: robokill
