Levin Top Speed :)
06-02-2006, 06:41 PM
Levin Top Speed :) | |||
06-02-2006, 07:41 PM
Levin Top Speed :)
I guess you are using the same gearbox as 4AGE thatswhy the final gear ratio is a bit short to reach higher speeds.
You can easily check your top speed from this diagram: "..el camino's aren't supposed to make sense, craziness is what makes the world go around." - Car & Driver, 1984 |
06-03-2006, 07:17 PM
Levin Top Speed :)
El_Camino
Where do you have that diagram from? I have measured my speed in the hachi, to 198km/h@7270rpm in 5. gear with gps and Apexi SAF-C. Youtube Myspace and I´ll Google your Yahoo |
06-06-2006, 10:50 AM
Levin Top Speed :)
Knudsen, this depends also from the tire diameter - I calculated it with my tires - 195/60/14. The final ratio is 4.1, and the gears as follows - 3,587, 2,022, 1,384, 1,000, 0,861
This is a japanese Excel file I have found I partly translated in English. "..el camino's aren't supposed to make sense, craziness is what makes the world go around." - Car & Driver, 1984 |
drifting extract from Top Gear TV programme UK | Stig | 2 | 5,416 |
08-02-2007 01:10 AM Last Post: robokill |
