Hoiw to remove the starter?
01-17-2005, 10:50 AM
Hi,
As I'll have to take the starter out of the engine bay, I'm wondering if anyone has already done it. If I'm right the starter is located near the oil filter, under the exhaust manifold. Any hints how to remove it ? Do I have to dismant also the oil filter ? Is it easier to do it from underneath the vehicle? Regards Andrej |
01-17-2005, 10:58 AM
1. Do it on a cold car. I have a wound on my hand from removing starter from a hot exhaust manifold.
2. Dissconnect the battery!!! 3. 2 bolts, bit tricky but can be done from the top side. I've done it this way. Drifting - best fun you can have in your car with your pants on! |
01-17-2005, 11:17 AM
Okay, I did this a couple of times, you have 2 options.
First is taking it out between manifold and firewall. You can squeeze it through there with a bit of twisting and turning. First you need to remove the little heatshield attached to the top of the starter, this makes it small enough to fit through, then remove the 2 bolts holding it to the bellhousing. Your best bet is to remove the lower bolt from under the car. Then there is option nr 2. Remove the heatshield from the starter as well, and remove oil filter, then take out from frontside. This is supposed to be easier. FABRICA MI DIEM, PVNC! |
01-17-2005, 11:20 AM
TNX to both
Andrej |
01-17-2005, 11:58 AM
This is great! I wondered how to do this for some time, as my starter sometimes has a problem turning when its warm - just ten times the last two years and none the last ½ year
Sarcasme is just one of the things I offer Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch |
01-17-2005, 02:25 PM
Do you still have the inner heat shield on your exhaust manifold? Starters tend to work a lot worse when they are heated up by the exhaust.
If you take out your starter, take a good look at the bearing inserts at both ends, mine were worn to a thin shell, I had them replaced for 5 euro's at an alternator overhaul shop. Stator brushes (if that's the correct name) are easily replacable, but I wouldnt replace them unless they are worn close to the minimum length specified in the manuals. FABRICA MI DIEM, PVNC! |
AE86 starter options | max_ae86 | 12 | 27,725 |
07-28-2019 08:17 PM Last Post: harkes |
Starter problems | Widar | 49 | 116,184 |
02-09-2015 10:11 AM Last Post: Ivan141 |
Starter Motor Help | phill 92 | 3 | 5,537 |
11-25-2013 11:16 AM Last Post: Apsogos |
Starter motor questions - rebuild | Jezza_hr | 6 | 7,294 |
08-31-2013 03:05 PM Last Post: Apsogos |
My new rebuilded denso starter (Heat soaked?) | Apsogos | 8 | 7,096 |
10-01-2012 07:43 PM Last Post: Apsogos |
