GTS MAXGRIP LSD rebuild kit
08-21-2008, 09:34 PM
MAXGRIP by Weir Performance. A real Performance rebuild kit for the O.E.M. GTS LSD. A great alternative to expensive aftermarket LSD's for builders on a budget. This kit is not glorified O.E.M. parts. Every part has been designed to get the maximum grip possible with an O.E.M. LSD unit. Our kit features larger diameter stationary plates and clutch plates. The increase in diameter increases the surface area a total of 23% over the O.E.M. plates. Also included is our Max size springs that increase spring load a total of 60lbs. force over O.E.M. Our kit also features reversible, solid bronze, thrust washers with slotted oil passages for improved oil flow to the bearing surface. The kit also comes with a complete shim kit that allows the installer to set the clearances within the LSD to the exact specs for best performance. What does all this mean? Quicker, more responsive LSD action with maximum grip! This kit is easily installed and we will post up a DIY soon with full instructions as well as initial torque readings before and after installing the MAXGRIP kit!
MAXGRIP kits are in stock and we are now taking orders. $190.00 plus CA sales tax if applicable. MAXGRIP initial torque readings and install instructions can be found here: http://forums.club4ag.com/zerothread?id=31135 We will be working on MAXGRIP kits for other LSD' soon. TRD O.E.M. Supra KAAZ, TOMEI MAZDA RX7 |
04-20-2009, 05:44 PM
PM !!
SC/TURBO axle & spool kit GTS | WeirPerformance | 13 | 18,755 |
09-07-2009 08:40 PM Last Post: raki |
MAXGRIP 7.5" Supra LSD kits | WeirPerformance | 1 | 3,429 |
03-17-2009 07:41 AM Last Post: WeirPerformance |
P.A.S.S ---- Rear End rebuild/ Kaaz Cusco lsd/crown & pi | SYM | 1 | 5,585 |
08-29-2007 11:38 AM Last Post: SYM |
