SC/TURBO axle & spool kit GTS
09-07-2009, 06:52 PM
raki Wrote:Excellent idea, but the problem is, that my 5,375 r+p is even weaker than the axle shafts, so i guess i have to cheange to another axle... That seems highly unlikely to me. We have installed the 5.375 TRD final drive in a car making over 200 RWHP. Never broke anything, not the ring and pinion or the axle shafts. Even the pinion gear in the 5.375 gear set is larger than the o.e.m. axle shaft. Remember, the ring and pinion is a torque multiplier, the axles see more torque than the ring and pinion. If you have 100 ftlbs. of torque at the pinion gear you will have 537 ft.lbs. at the axle shaft. |
09-07-2009, 08:04 PM
WeirPerformance Wrote:We are working on doing this same upgrade for LSD's. TRD will be the first LSD we will make this fit, Kaaz, Tomei will be next. We will post when it's ready. Thanks, excellent! |
09-07-2009, 08:40 PM
WeirPerformance Wrote:raki Wrote:Excellent idea, but the problem is, that my 5,375 r+p is even weaker than the axle shafts, so i guess i have to cheange to another axle... Maybe the preowner of the car did just not install the r+p good enough, but the pinion is really damaged. But axle shafts I also broke some axle shafts, thats rally... I think thereĀ“s a reason, all the finnish people drive Volvo-axles.. http://www.sg-rallyesport.de |
Shift Gear Clothing - Toyota, Mazda, Turbo, various | tomstwincam | 16 | 18,362 |
07-09-2012 03:37 AM Last Post: tomstwincam |
Project Mu&Spirits-AutoWork crossover Big Brake Kit For | Spirits Racing | 6 | 8,580 |
06-13-2011 07:55 PM Last Post: Spirits Racing |
GTS MAXGRIP LSD rebuild kit | WeirPerformance | 2 | 7,425 |
04-20-2009 05:44 PM Last Post: eg6maxx |
