seized caliper
09-21-2007, 12:50 AM
seized caliper
hey guys... couple of months ago all four of my calipers seized up on me so i decided to relplace all of my calipers..so i did..now my right rear side caliper is seized again and its brand new and can't figure out what the problem is..anyone have any ideas?
09-21-2007, 02:06 AM
seized caliper
what do you mean with seized?
[Image: AEU86 AE86 - seized caliper]
09-21-2007, 08:29 AM
seized caliper
maybe one of your lines is not handling the pressure. Did you change your flexible lines? I would change the hard lines on the rear axle as well. Just to be sure.
09-21-2007, 05:50 PM
seized caliper
Maybe it's a problem with your handbrake cables? I doubt a new caliper would seize up , unless your braking fluid is full of junk. Try to elaborate on why you think it is seized, what have you tested?
09-22-2007, 08:27 AM
seized caliper
im not a 100% sure it is seized but after i drive around for like 10 minutes i rim would get really hot and my rotors is just heating up badly..so im guessing my pads arent being released. heres my question when u change the rear pads or caliper do you have to do anything special to th handbrake cable etc..?
09-22-2007, 11:48 AM
seized caliper
Hi drift,
Are you sure the pads aren't simply stuck in the bracket? You have these little metal thingies at the side that help them move but if these are installed wrong or if these are dirtly or if it doesn't all fit right, the pads can get stuck in the brackets and not release while the caliper itself is fine.
What you could try to do is take the pads out, give the bracket and the metal insets a good clean, sand the metal bits that stick out on the backplate of the pads a little so they move well and easy within the bracket, and lubricate them a bit with copper grease or something similar.
The pads should move without obstruction within the brackets.
09-22-2007, 12:41 PM
seized caliper
drft_ae86 Wrote:Here is my question; when u change the rear pads or caliper
do you have to do anything special to the handbrake cable etc..?
Nothing special with the cable, but you should wind the piston back into
the caliper to allow the new pads to fit correctly. There is a spring loaded
spiral rachet thingy (technical term Tongue ) in behind that automatically
adjusts the handbrake as the pads wear.
If you don't wind the piston back in, you could have problems fitting new
pads, but hardly likely to be a problem with brand new calipers.
Cheers... jondee86
09-23-2007, 09:22 AM
seized caliper
thanks guys i'll give that a try and see what happens
09-23-2007, 02:07 PM
seized caliper
If your entire hub assembly is getting hot, it might also be a wheel bearing on it's way out.. mine would heat up the entire rim when I had that problem.
If you can freely turn the wheel when it's jacked up, then you can be pretty sure it's not the caliper..try to test this with hot and cold conditions (it's probably best to lift the entire rear axle on axle stands).
09-27-2007, 12:42 AM
seized caliper
the metal shim on the back of the pads is to stop brake squeel and shouldn't affect their performance in any way. Maybe the brakes are sticking due to an air lock somewhere in the system :wink:
Live life on the red line
  Rear Caliper Rebuild mad.matt 16 23,946 01-19-2017 02:19 PM
Last Post: Project D
  Toyota rear caliper totta Crolla 8 12,380 02-02-2014 11:19 PM
Last Post: totta Crolla
  brake caliper/line fitting Eifelaner 9 16,346 04-15-2013 11:38 AM
Last Post: Eifelaner
  max brake disc thickness ae86 caliper+heel and toe question ditn 26 37,086 10-02-2012 05:00 PM
Last Post: ditn
  AE86 Rear Brake Upgrade - Caliper & Discs? Conrad 18 45,299 08-07-2009 01:36 PM
Last Post: Wild KE
