oldskull's Levin
10-14-2006, 11:17 AM
Post: #121
oldskull's Levin
You probably just blew a fuse... whatever you do..make sure that all the usual lights work when you take it to the APK.
I can help you out with wiring them up properly some day.
10-14-2006, 12:16 PM
Post: #122
oldskull's Levin
I already checked the fuses in de enginebay, so I just found 1 was blew. So I already replaced the new one. But the light inside the car and boot also the fog lights still not worked.
Thanks for the offer Ivan. Thumbs up!
10-15-2006, 11:11 AM
Post: #123
oldskull's Levin
Check the fuses in the driver side kick-panel.. (under the little panel left of your pedals), I think the accessory fuse is somewhere in there.
And remember to be carefull with the electronics in the future, it's important to have an idea of what your doing.
10-15-2006, 11:13 AM
Post: #124
oldskull's Levin
Ivan: I think I know where the fuse I should look. After looking and reading in the AE86 Electrical Wiring Diagram book I found where is the fuse for door lamp, boot lamp and rear fog lamp Smile So I am going to get some fuses for my car now
10-15-2006, 12:49 PM
Post: #125
oldskull's Levin
Oldskull: do the 3 door lights feature a foglight? I know the 2 doors never featured a foglight at all, so maybe it used to be wired up the same as mine. Confused
[Image: AEU86 AE86 - oldskull's Levin]
10-15-2006, 04:22 PM
Post: #126
oldskull's Levin
banpei: I dont know how to explain, but the EU rear lights the one next to number plate is fog lights. I think picture will explain well.
10-15-2006, 04:27 PM
Post: #127
oldskull's Levin
and this I think the US one, but if not should it possible to do this?
10-15-2006, 09:53 PM
Post: #128
oldskull's Levin
Perhaps this can clearify as well:
No foglights connected to the taillights.
However, you can do it yourself ofcourse. Have a double relay connected to the foglight: one for normal light/brake function and another relay for the foglights. That way the foglights can't amp the normal lights, while the normal lights still can light up the foglights. Then you probably need a resitor to keep the foglight not illuminating fully the whole time when you use your normal lights. Wink
Also, about the interior light:
Perhaps this can help Wink
10-22-2006, 09:12 PM
Post: #129
oldskull's Levin
Is er iemand toevallig extra 'panhard' heeft? (ik weet niet wat precies dit ding noemt) Die van me is een beetje krom. Ik hoop dat voor APK geen grote probleem is.
10-22-2006, 09:44 PM
Post: #130
oldskull's Levin
oldskull, das een van de 4linksBig Grin
Panhard is die ene die in de breedte zit.
Heb er helaas niet eentje over....
