max overbore
10-25-2005, 04:49 AM
max overbore
whats the maximum overbore for the 4a-ge
10-25-2005, 10:34 AM
max overbore
83mm (t.e. +2mm).
10-25-2005, 10:44 AM
max overbore
I think it's different for 3-rib and 7-rib engines...the later 7-rib can be overbored the most.. dunno which values are correct though.
10-25-2005, 12:59 PM
max overbore
normal oversizes go by 0,5 or even 0,25mm
standard pistons from toyota reach a max of 82 mm but some use 83
I wouldn't go higher then 82mm or than get a 7afe if you want more torgue
10-25-2005, 01:59 PM
max overbore
thanks guys Smile
  Anyone got Max Orido's Magical Fuse? banpei 7 8,706 02-08-2024 11:09 AM
  Max lift on Vitz valve lifters harkes 9 15,462 01-02-2014 10:27 AM
  max brake disc thickness ae86 caliper+heel and toe question ditn 26 36,690 10-02-2012 05:00 PM
Last Post: ditn
  track questions:max oil/water temp,egt and other ditn 7 10,920 07-06-2012 12:40 PM
Last Post: ditn
  Work equip 01 max offset?? stalker 5 11,907 08-23-2011 03:09 AM
Last Post: Lewy
