Poll: What sort of flywheel are you using?
Stock AE86 (10kg?)
< 4 kg (TODA, TRD?, Fidanza..)
4-6 kg (HKS..)
> 6 kg - aftermarket (which?)
machined oem unit
other (what?)
[Show Results]
flywheel options - What are you using?
04-24-2007, 07:06 AM
the oem flywheels for the 16V and 20V silvertop are 7.2 kilos and 7 kilos... the blacktop flywheels is 6 kilos. It is steel and it is CHEAP! Can you say under $200(USA dollars) Blacktop flywheel part number is 13405-16110
[Image: AEU86 AE86 - flywheel options - What are you using?]
Dan -
04-24-2007, 08:29 AM
I have the Dog Fight Pro 3.7kg steel flywheel in my 86. It's mostly identical to the Toda one, except for a slightly different tapering on the backside, near the center.
04-24-2007, 10:07 AM
i have the Ez stage 3 4.7 kilo
04-24-2007, 04:51 PM
@oldskewltoy: I thought 20v flywheels didnt fit in the t50 bellhousing?
04-24-2007, 05:38 PM
Ivan141 Wrote:@oldskewltoy: I thought 20v flywheels didnt fit in the t50 bellhousing?
No, they fit.
The compatibility issue is that you need the larger 212 clutch, instead of the stock 200mm clutch. (IIRC)
I'm running a 3.7 kg as well (looks identical to the 'dogfight' one) which I picked up off of ebay.
http://cgi.ebay.com/ebaymotors/Bullet-St...enameZWD1V
Andrew
04-24-2007, 11:20 PM
Lightening flywheels needs to be done with some understanding
of the dynamics. If the weight can be removed from the outer rim
without affecting the structural integrity of the flywheel, or creating
stress risers, there should be no problem.
I have lightened a stock smallport as per the attached pic. I am using
it with an OEM 212 mm clutch kit inside a T50. Works just fine Smile
http://homepages.ihug.co.nz/~wjd/fly01.jpg
Cheers... jondee86
04-25-2007, 12:30 AM
@guys with 4kgs or less: how does the car feel for normal street driving? is it still okay, or does the car feel to quirky to drive?
04-27-2007, 04:40 AM
Apolan Wrote:@guys with 4kgs or less: how does the car feel for normal street driving? is it still okay, or does the car feel to quirky to drive?
It's fine for street driving, actually I have no issues even when visiting san francisco and all it's hills. Once you get used to the lightness and it becomes the norm you'll love it.
Andrew
  Bigger brake master cylinder options Koen 10 3,798 01-08-2026 03:12 PM
Last Post: r.ave
Thumbs Up ITB filter options mister86 1 5,571 12-06-2020 10:44 AM
  AE86 starter options max_ae86 12 39,042 07-28-2019 08:17 PM
Last Post: harkes
  light weight Flywheel filh 9 11,795 02-05-2018 05:20 PM
Last Post: filh
  AE86 rear suspension options 2018 Alex 9 16,578 01-24-2018 02:25 PM
