flywheel options - What are you using?
04-24-2007, 07:06 AM
the oem flywheels for the 16V and 20V silvertop are 7.2 kilos and 7 kilos... the blacktop flywheels is 6 kilos. It is steel and it is CHEAP! Can you say under $200(USA dollars) Blacktop flywheel part number is 13405-16110
04-24-2007, 08:29 AM
I have the Dog Fight Pro 3.7kg steel flywheel in my 86. It's mostly identical to the Toda one, except for a slightly different tapering on the backside, near the center.
04-24-2007, 10:07 AM
i have the Ez stage 3 4.7 kilo
04-24-2007, 04:51 PM
@oldskewltoy: I thought 20v flywheels didnt fit in the t50 bellhousing?
04-24-2007, 05:38 PM
Ivan141 Wrote:@oldskewltoy: I thought 20v flywheels didnt fit in the t50 bellhousing? No, they fit. The compatibility issue is that you need the larger 212 clutch, instead of the stock 200mm clutch. (IIRC) I'm running a 3.7 kg as well (looks identical to the 'dogfight' one) which I picked up off of ebay. http://cgi.ebay.com/ebaymotors/Bullet-St...enameZWD1V Andrew |
04-24-2007, 11:20 PM
Lightening flywheels needs to be done with some understanding
of the dynamics. If the weight can be removed from the outer rim without affecting the structural integrity of the flywheel, or creating stress risers, there should be no problem. I have lightened a stock smallport as per the attached pic. I am using it with an OEM 212 mm clutch kit inside a T50. Works just fine ![]() http://homepages.ihug.co.nz/~wjd/fly01.jpg Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
04-25-2007, 12:30 AM
@guys with 4kgs or less: how does the car feel for normal street driving? is it still okay, or does the car feel to quirky to drive?
04-27-2007, 04:40 AM
Apolan Wrote:@guys with 4kgs or less: how does the car feel for normal street driving? is it still okay, or does the car feel to quirky to drive? It's fine for street driving, actually I have no issues even when visiting san francisco and all it's hills. Once you get used to the lightness and it becomes the norm you'll love it. Andrew |
| Bigger brake master cylinder options | Koen Bongers | 10 | 1,328 |
01-08-2026 03:12 PM Last Post: r.ave |
| ITB filter options | mister86 | 1 | 4,686 |
| AE86 starter options | max_ae86 | 12 | 35,334 |
| light weight Flywheel | filh | 9 | 9,594 |
02-05-2018 05:20 PM Last Post: filh |
| AE86 rear suspension options 2018 | Alex | 9 | 14,566 |
01-24-2018 02:25 PM Last Post: mad.matt |
