flywheel balance
06-27-2010, 07:19 PM
flywheel balance
fitting another engine and I want to use a lightened steel flywheel. I'm not shure it has been balanced properly.
The replacement engine has a flywheel fitted, should I have the steel one balanced as per the factory one fitted or should it just be balanced independantly ? Thanks, TC An analogue brain in a digital World |
06-27-2010, 07:29 PM
flywheel balance
in a ideal world the flywheel is balanced together with the crank and clutchcover... but if you get the flywheel balance properly on it's own you should be fine.
AE86 ex-daily |
06-28-2010, 11:17 AM
flywheel balance
so if I get it balanced the same as the one I take off it will be ok ?
06-28-2010, 11:21 AM
flywheel balance
simply get it balanced as good as possible (like a wheel) that's it.
AE86 ex-daily |
| light weight Flywheel | filh | 9 | 10,345 |
02-05-2018 05:20 PM Last Post: filh |
| crank 6 bolt flywheel | DJexor | 5 | 10,460 |
12-05-2016 08:21 AM Last Post: d3nso |
| Flywheel fitting | totta Crolla | 11 | 16,389 |
11-24-2013 05:31 PM Last Post: Apsogos |
| Mikuni carb help just wont balance | megabob | 3 | 6,810 |
01-01-2013 10:32 PM Last Post: allencr |
| Flywheel and clutch kit | 86Pilot | 1 | 4,411 |
12-01-2011 01:26 PM Last Post: 86Pilot |
