flywheel balance
06-27-2010, 07:19 PM
flywheel balance
fitting another engine and I want to use a lightened steel flywheel. I'm not shure it has been balanced properly.
The replacement engine has a flywheel fitted, should I have the steel one balanced as per the factory one fitted or should it just be balanced independantly ?
Thanks, TC
06-27-2010, 07:29 PM
flywheel balance
in a ideal world the flywheel is balanced together with the crank and clutchcover... but if you get the flywheel balance properly on it's own you should be fine.
AE86 ex-daily
06-28-2010, 11:17 AM
flywheel balance
so if I get it balanced the same as the one I take off it will be ok ?
06-28-2010, 11:21 AM
flywheel balance
simply get it balanced as good as possible (like a wheel) that's it.
AE86 ex-daily
  light weight Flywheel filh 9 11,717 02-05-2018 05:20 PM
Last Post: filh
  crank 6 bolt flywheel DJexor 5 11,255 12-05-2016 08:21 AM
Last Post: d3nso
  Flywheel fitting totta Crolla 11 17,414 11-24-2013 05:31 PM
Last Post: Apsogos
  Mikuni carb help just wont balance megabob 3 7,281 01-01-2013 10:32 PM
Last Post: allencr
  Flywheel and clutch kit 86Pilot 1 4,776 12-01-2011 01:26 PM
Last Post: 86Pilot
