ZDoman's projects - Hungary
12-11-2006, 11:23 PM
Post: #41
I took a look around my workshop. found some metal parts and welded an engine stand of them Cool
[Image: AEU86 AE86 - ZDoman's projects - Hungary]
and then I started to part the engine (4.2.2006)
The intake manifold also had the coal-tar?/coat:
12-11-2006, 11:41 PM
Post: #42
5.2.2005
oil squirter
Piston and cylinder seemt good at this point I didn't know why had compression lost from the engine
But the conrod bearings were worn.
12-11-2006, 11:42 PM
Post: #43
Thumbs up! Thumbs up! Nice project mate, keep them coming Smile
12-11-2006, 11:59 PM
Post: #44
Maybe this was the problem with the compression:
Some coal was on the exhaust valve seats.
But on all of the 8 valves so I don't know why just the cyl 2-3 had comp loss... :roll:
I had a big trouble with the crank timing pulley, I wasn't able to pull it down.
Finally I drilled a hole and broke it down...
12-12-2006, 12:20 AM
Post: #45
I've sent the main parts to hot leaching/lixiviation bath
results were Thumbs up! (pictures took on 7.2.2006)
12-12-2006, 12:39 AM
Post: #46
The exhaust valves had some kind of coat. It was very hard on the valves I tried some kind of chemicals but no one made anyting. finally I removed them with Flex (angle grinder?) and steel brush...
So here I started some head porting. I just wanted to remove the big materials that 100% not needed and are in the way of the air.
Nothing serious...
The "tools" Cool
The base again on the intake side:
First steps:
12-12-2006, 12:44 AM
Post: #47
First step on the exhaust side:
second step Smile
from the combustion chamber side:
12-12-2006, 12:50 AM
Post: #48
Mates
please tell me if you don't want so much pictures.
I can take in only before & after pictures also...
12-12-2006, 11:25 AM
Post: #49
Noooo, we want article too ! Evil
12-12-2006, 01:41 PM
Post: #50
Ofcourse we want to see more! Smile
One hell of a topic already. >Smile
Hehe... I see you're hosting the images yourself. You can also attach them to the posts if you want to. But its your bandwidth. Tongue
  ZaX's new projects ZaX 6 6,419 01-21-2023 07:23 PM
  My Friend's Projects Started. ToyotaTs 72 85,061 01-19-2010 08:24 PM
Last Post: oldskull
  Drift project from Hungary AE86_Z 66 117,342 12-14-2008 12:37 PM
Last Post: AE86_Z
  Foto from ROTACHI projects 2009 jardapek 3 7,659 11-17-2008 11:02 PM
Last Post: jardapek
  Projects section rules banpei 2 43,457 02-18-2005 11:24 AM
