ZDoman's projects - Hungary
12-11-2006, 11:23 PM
Post: #41
I took a look around my workshop. found some metal parts and welded an engine stand of them
![]() ![]() and then I started to part the engine (4.2.2006) The intake manifold also had the coal-tar?/coat: ![]() ![]() ![]() ![]() ![]() ![]()
12-11-2006, 11:41 PM
Post: #42
5.2.2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() oil squirter ![]() Piston and cylinder seemt good at this point I didn't know why had compression lost from the engine ![]() But the conrod bearings were worn.
12-11-2006, 11:42 PM
Post: #43
12-11-2006, 11:59 PM
Post: #44
![]() ![]() ![]() Maybe this was the problem with the compression: ![]() Some coal was on the exhaust valve seats. But on all of the 8 valves so I don't know why just the cyl 2-3 had comp loss... :roll: ![]() ![]() ![]() ![]() ![]() I had a big trouble with the crank timing pulley, I wasn't able to pull it down. ![]() Finally I drilled a hole and broke it down...
12-12-2006, 12:20 AM
Post: #45
I've sent the main parts to hot leaching/lixiviation bath
results were ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
12-12-2006, 12:39 AM
Post: #46
The exhaust valves had some kind of coat. It was very hard on the valves I tried some kind of chemicals but no one made anyting. finally I removed them with Flex (angle grinder?) and steel brush...
![]() So here I started some head porting. I just wanted to remove the big materials that 100% not needed and are in the way of the air. Nothing serious... The "tools" ![]() ![]() The base again on the intake side: ![]() ![]() ![]() First steps: ![]() ![]()
12-12-2006, 12:44 AM
Post: #47
First step on the exhaust side:
![]() second step ![]() ![]() from the combustion chamber side: ![]() ![]() ![]() ![]() ![]() ![]()
12-12-2006, 12:50 AM
Post: #48
Mates
please tell me if you don't want so much pictures. I can take in only before & after pictures also... |
12-12-2006, 11:25 AM
Post: #49
Noooo, we want article too !
12-12-2006, 01:41 PM
Post: #50
Ofcourse we want to see more!
![]() One hell of a topic already. > ![]() Hehe... I see you're hosting the images yourself. You can also attach them to the posts if you want to. But its your bandwidth.
| ZaX's new projects | ZaX | 6 | 6,134 |
01-21-2023 07:23 PM Last Post: ZaX |
| My Friend's Projects Started. | ToyotaTs | 72 | 81,865 |
01-19-2010 08:24 PM Last Post: oldskull |
| Drift project from Hungary | AE86_Z | 66 | 114,977 |
12-14-2008 12:37 PM Last Post: AE86_Z |
| Foto from ROTACHI projects 2009 | jardapek | 3 | 7,431 |
11-17-2008 11:02 PM Last Post: jardapek |
| Projects section rules | banpei | 2 | 43,018 |
02-18-2005 11:24 AM Last Post: banpei |
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/105.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/104.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/106.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/107.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/108.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/109.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/110.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/111.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/113.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/114.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/115.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/116.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/117.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/118.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/119.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/120.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/121.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/123.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/124.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/125.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/126.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/127.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/128.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/129.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/130.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/131.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/132.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/134.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/135.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/136.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/137.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/138.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/139.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/140.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/141.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/142.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/143.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/144.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/147.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/148.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/145.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/149.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/150.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/151.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/152.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/153.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/154.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/155.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/156.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/158.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/159.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/160.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/161.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/162.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/163.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/164.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](http://www.doman.hu/aeu86/165.jpg)
![AEU86 AE86 - ZDoman's projects - Hungary [Image: AEU86 AE86 - ZDoman's projects - Hungary]](https://www.aeu86.org/sticker-banner-468.gif)
