Wheel stud specifications?
05-19-2013, 06:27 PM
Does anyone know the width/diameter/thread etc for the standard wheel studs? I'm looking to buy a set, but I've been told it's less costly to go through a third party supplier instead of Toyota direct.
05-19-2013, 08:48 PM
![]() Thread: M12x1.5 Length: OEM are short, something like 45mm. But you can use longer one. |
05-19-2013, 09:10 PM
Brilliant, thank you
05-20-2013, 11:35 AM
The ones from a lexus ls200 are longer i believe
AE86 Levin |
08-13-2013, 08:21 AM
Making use of this thread as the title is searchable
![]() I was researching this topic recently, as I scored some vintage Watenabes for my AE86, and found the stock studs were not long enough to get the proper number of turns on the wheel nuts. This is what I found... ![]() The only useful measurement is the length (measured from under the head) as hub thickness and brake discs can affect the amount of stud you can see. All of these studs have the 14.17-14.20 knurl and will happily pull into AE86 hubs without raising a sweat. A lot of the Toyota studs are used on more than one vehicle, and may have "replaced by" part numbers different from the original. EDIT: Toyota Part: 90942-02037 Replaced By: 90942-02049. Which means the MR2, Previa, Prado, Hi-Lux, Lexus etc all use the same stud. EDIT: These also work... http://www.summitracing.com/parts/arp-100-7715 66 long with 14.17 knurl... you might have pull the axles to fit them. Cheers... jondee86 |
| Spare wheel & spare wheel carrier | ondafly | 6 | 2,156 |
01-19-2026 01:00 PM Last Post: ondafly |
| specifications for LSD rebuild | H7ERO | 53 | 75,839 |
04-11-2011 09:59 AM Last Post: T_AE86 |
![AEU86 AE86 - Wheel stud specifications? [Image: AEU86 AE86 - Wheel stud specifications?]](http://i828.photobucket.com/albums/zz202/danc8000/Wheel%20studs/a23cb656.jpg)
![AEU86 AE86 - Wheel stud specifications? [Image: AEU86 AE86 - Wheel stud specifications?]](http://homepages.paradise.net.nz/~wjd/toystud1.jpg)
