Wheel adapters - track safe?
02-02-2014, 06:23 AM
Drill the wheels?
02-02-2014, 01:11 PM
Kinda OT:
Steering wheel WILL shake over 100 kph when wheels spigot diameter > hub diameter without rings.
Many cars, many times, sometimes more, sometime less but good spigot rings will be needed if there is difference in hub/spigot diameter.
02-02-2014, 03:06 PM
No it won't, steering wheel will shake if your tyres/wheels aren't properly balanced. I've been running wheels without spigot rings for years, if properly balanced there won't be ANY shake.
02-02-2014, 08:12 PM
The issue is more about safety than wheels shaking.
http://planetsoarer.com/offset/studs.htm
Just one example of many.
02-03-2014, 03:05 AM
The Doctor Wrote:No it won't, steering wheel will shake if your tyres/wheels aren't properly balanced. I've been running wheels without spigot rings for years, if properly balanced there won't be ANY shake.
Yes it will, wheel is out of axis by mm or two.
But, i agree to disagree Smile
02-03-2014, 06:16 PM
totta Crolla Wrote:The issue is more about safety than wheels shaking.
I can't believe that has something to do with spigotrings.
At the moment your wheelnuts are torqued to the correct level, there is no real stress on the bolts/studs, as all of the force is 'transmitted' through the hub by the clamping force (i don't know how to put this correctly in english) and not on the bolts/studs.
02-04-2014, 02:42 AM
Looking at this pic...
[Image: AEU86 AE86 - Wheel adapters - track safe?]
... it appears that the wrong studs were used, as there is
clear evidence that the thread went all the way thru the rotor.
Studs of the correct type have smooth shank inside the thickness
of the rotor, with a larger diameter. The thread does not start until
the stud is a small distance outside the rotor.
Most likely the studs were not correctly torqued for the new
larger diameter wheels, and this allowed the wheel or rotor to
move on the hub. The studs were then subject to bending forces
that caused a fatigue failure, probably originating in the root of
the first thread.
Hub centric rings would not have prevented this failure. The interweb
is full of misinformation and psuedoscience promulgated by people
who take as gospel the BS put out by other people who want to sell
their products to a gullible public.
The AE86 came from the factory with hubcentric wheels and shank
and washer type lug nuts. This is the absolute best wheel and nut
design without question. However, if non-hubcentric wheels and cone
faced nuts were as dangerous as some people make out, they would
be used in warfare instead of bullets Smile
Cheers... jondee86
02-04-2014, 03:07 AM
@jondee86: Very well said Wink
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
02-04-2014, 12:21 PM
jondee86 Wrote:The AE86 came from the factory with hubcentric wheels and shank
and in a track / competition environment nothing less should suffice.
Cone face nuts were used by Toyota on AE86 steel rims.
  Spare wheel & spare wheel carrier ondafly 6 2,257 01-19-2026 01:00 PM
Last Post: ondafly
  Wide Track 86 Mylesmck 8 6,560 05-28-2023 09:51 PM
  wider rear axle,track width,suspension questions ditn 6 13,512 10-18-2016 11:50 AM
Last Post: fantapants
  DIV 1 rally/track suspension setup ditn 60 97,188 03-28-2013 11:28 PM
Last Post: ditn
  track questions:max oil/water temp,egt and other ditn 7 11,261 07-06-2012 12:40 PM
Last Post: ditn
