Wheel adapters - track safe?
02-02-2014, 06:23 AM
Drill the wheels?
02-02-2014, 01:11 PM
Kinda OT:
Steering wheel WILL shake over 100 kph when wheels spigot diameter > hub diameter without rings. Many cars, many times, sometimes more, sometime less but good spigot rings will be needed if there is difference in hub/spigot diameter. |
02-02-2014, 03:06 PM
No it won't, steering wheel will shake if your tyres/wheels aren't properly balanced. I've been running wheels without spigot rings for years, if properly balanced there won't be ANY shake.
02-02-2014, 08:12 PM
The issue is more about safety than wheels shaking.
http://planetsoarer.com/offset/studs.htm Just one example of many. An analogue brain in a digital World |
02-03-2014, 03:05 AM
The Doctor Wrote:No it won't, steering wheel will shake if your tyres/wheels aren't properly balanced. I've been running wheels without spigot rings for years, if properly balanced there won't be ANY shake. Yes it will, wheel is out of axis by mm or two. But, i agree to disagree
02-03-2014, 06:16 PM
totta Crolla Wrote:The issue is more about safety than wheels shaking. I can't believe that has something to do with spigotrings. At the moment your wheelnuts are torqued to the correct level, there is no real stress on the bolts/studs, as all of the force is 'transmitted' through the hub by the clamping force (i don't know how to put this correctly in english) and not on the bolts/studs. "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
02-04-2014, 02:42 AM
Looking at this pic...
![]() ... it appears that the wrong studs were used, as there is clear evidence that the thread went all the way thru the rotor. Studs of the correct type have smooth shank inside the thickness of the rotor, with a larger diameter. The thread does not start until the stud is a small distance outside the rotor. Most likely the studs were not correctly torqued for the new larger diameter wheels, and this allowed the wheel or rotor to move on the hub. The studs were then subject to bending forces that caused a fatigue failure, probably originating in the root of the first thread. Hub centric rings would not have prevented this failure. The interweb is full of misinformation and psuedoscience promulgated by people who take as gospel the BS put out by other people who want to sell their products to a gullible public. The AE86 came from the factory with hubcentric wheels and shank and washer type lug nuts. This is the absolute best wheel and nut design without question. However, if non-hubcentric wheels and cone faced nuts were as dangerous as some people make out, they would be used in warfare instead of bullets ![]() Cheers... jondee86 |
02-04-2014, 03:07 AM
@jondee86: Very well said
02-04-2014, 12:21 PM
jondee86 Wrote:The AE86 came from the factory with hubcentric wheels and shank and in a track / competition environment nothing less should suffice. Cone face nuts were used by Toyota on AE86 steel rims. An analogue brain in a digital World |
| Spare wheel & spare wheel carrier | ondafly | 6 | 1,422 |
01-19-2026 01:00 PM Last Post: ondafly |
| Wide Track 86 | Mylesmck | 8 | 5,559 |
05-28-2023 09:51 PM Last Post: Bean |
| wider rear axle,track width,suspension questions | ditn | 6 | 12,594 |
| DIV 1 rally/track suspension setup | ditn | 60 | 91,232 |
03-28-2013 11:28 PM Last Post: ditn |
| track questions:max oil/water temp,egt and other | ditn | 7 | 10,470 |
07-06-2012 12:40 PM Last Post: ditn |
![AEU86 AE86 - Wheel adapters - track safe? [Image: AEU86 AE86 - Wheel adapters - track safe?]](http://planetsoarer.com/offset/4686.jpg)
