Tureno 4agte engine rebuild :D
09-24-2010, 01:37 PM
Hi all blow my engine on my ae86
any way here are some pic's here's the car looking sad ![]() ![]() Now you see it Now you dont magic! ![]() ![]() also has a os Giken super single clutch which is nice the only thing bad about is its pretty worn out which is not nice as a rebuild kit cost 300+ quid http://www.rhdjapan.com/os-giken-super-s...it-a-11947 ![]() ![]() ![]() also striped the block to see what had failed a lot of guys were saying that the ring lands have gone and I was thinking it was the piston rings which have failed but both the rings and the ring lands are f***ed piston no.1 bottom compression ring has multiple cracks and the ringland fell apart in my hands ![]() ![]() ![]() pistons 2 and 3 were ok piston 4 had some cracks on the ring land ![]() ![]() ![]() thats all for now will update when I get more stuff done |
09-24-2010, 02:18 PM
looking forward to the rebuild project
09-24-2010, 05:25 PM
Typical 4age problem... my first engine did that too.. Think it's overheating / bad lubrication or something similar. Usually nr4 cylinder that gets the worst of it iirc.
09-24-2010, 10:41 PM
Ivan141 Wrote:Typical 4age problem... my first engine did that too.. Think it's overheating / bad lubrication or something similar. Usually nr4 cylinder that gets the worst of it iirc. yeah was a pretty hot day the day it blow up water temp went over 95-100 normally around 80 I just hope it wont happen again lol |
09-24-2010, 10:43 PM
Ok here comes the fun part, all my nice and new and shiny parts
..................but took over 2 months to get them all!! ![]() ![]() in the pic's: Arias 82mm forged low compression pistons (8.6:1) Spool H-beam Con rods ARP rod bolts ARP Head studs ARP Main studs ARP Flywheel bolts ACL Main bearings ACL Con rod bearings ACL Thrust washers Driftworks Magnetic sump plug INNOVATE XD-16 16 in 1 WIDEBAND GAUGE KIT HKS Fine tune Timing belt Zakleecorp clear cam cover Toyota Oil pump Toyota Water pump Toyota engine gasket kit Cheap oil filter Continental drive belt Cam cover washer seals (did not come with the Toyota engine gasket kit!!) Camshaft oil seals (did come with the Toyota engine gasket kit but I lost one and broke the other oops :rolleyes: ) Not in the pic's: HKS Cam gears HKS 1.6mm Metal Head gasket Kelsport 4age sump pan bolt kit OS giken clutch rebuild kit A Denso IK22 Spark plugs Cheap engine oil Mocal 19row oil cooler Ported and polished head done by me Engine Machine work done: Rebore Block new core plugs block skimed head skimed crankshaft balanced and polished Parts purchased before Garret gt2860r cheap ebay intercooler autobahn88 de-cat pipe more pic's to follow |
09-25-2010, 02:36 PM
sick, but maybe look into a bit smaller turbo ? like a gt25? that would still make 300 hp. But will make the engine more durable ?
09-26-2010, 01:32 PM
robokill Wrote:sick, but maybe look into a bit smaller turbo ? like a gt25? that would still make 300 hp. But will make the engine more durable ? too late now got the turbo already should still be ok tho back to the build here's my work bench the boot lid of my skyline lol :lol: ![]() the block cleaned,sanded down,sprayed then cleaned again ready for bearing and crankshaft installation ![]() ![]() crankshaft installed and torqued down ![]() ![]() Now the next part is to measure each piston ring and file it (if needed) to spec's now this is a long because you have to put the ring square in the bore then measure it if it to small(which they all are, none of them are the right size out of the box) then you take it out and then file a little then place it back in the bore measure and repeat until it the right size and you have to do this for every single ring!! :yawn: lets just say I started at 11am and finished at 5am in the morning!! :yawn: (Watch the SR20 rebuild vid I posted to see how it is done) Mounting the arias pistons and the spool conrods looking sexy :thumbsup: ![]() putting the bloody rings in lol :lol ![]() ![]() pistons mounted and torqued to spec ![]() ![]() ![]()
09-27-2010, 05:28 PM
ok so more pic's, I sprayed the sump in high temp matt black which I think looks pretty badass B)
oil pump,sump,driftworks sump plug and the kelsport bolts installed and torqued down to spec ![]() closer pic of the matt colour and the bolts ![]() I liked the colour of the sump so much that I had to spray the cam covers the same! ![]() ![]() ![]() ![]() ![]() next the arp head studs installed ![]() ![]()
09-29-2010, 01:26 PM
pic's of the ported and polished head done by me which I think came out Ok could have spent more time on it but it all good
![]() ![]() ![]() valves in ![]() shim and buckets cleaned and ready for installation ![]() HKS metal head gasket installed ![]() ![]() Head installed and torqued to spec ![]() ![]() ![]() camshafts installed ![]() ![]() a quick pic to see how the covers look like on the engine (I know there in the wrong way but hay it was 5 in the morning and I was tried :yawn: :lol: )
11-06-2010, 03:02 PM
ok some more updates
backing plate cleaned and fitted ![]() ![]() Cam covers cam pulleys and hks belt installed looking sexy.............hhhhhhhmmmmmmmmm purple... :drool: (sorry for the crappy pic's ![]() ![]() ![]() Some of you may have noticed the cam cover's are different colour,I dropped some parts cleaner on them while I was cleaning the garage (Doh!!) ran out of that High temp matt spray went to my local halfords but they didn't have any ![]() new water pump installed ![]() ![]() A quick preview of the clear cam cover B) ![]() ![]() rest of the water pipes alternator etc on ![]() ![]() more pic's of the cams and the HKS belt some of maybe thinking why is one of them look newish and one of them look old well I had them in my Gti but I did not have them covered up so I am guessing some dirt and grim got on one of them and took the paint off ![]() ![]() pic's of the clutch cleaned the clutch cover came out well also looks really cool you can't it in the pic's but its like multi-coloured if you look at it in different angles it goes purple,gold,green,different shades of blue looks badass shame you wont see it when its in ![]() ![]() new clutch plate,bolts and the thingy plate lol dont know what its called :lol: ![]() flywheel and arp bolts installed ![]() inlet,exhaust and turbo installed ![]() ![]() engine installed magic!! ![]() will get some vids up of it running :thumbsup: sounds really different
| Scottish Trueno rebuild - Nürburgring with pics! | kazi | 77 | 214,904 |
11-25-2018 11:42 PM Last Post: kazi |
| Patrick's rebuild topic | PatrickAE86 | 13 | 24,026 |
11-22-2017 05:49 PM Last Post: The Doctor |
| Blacktop out 4AGTE in | Hopi | 47 | 58,486 |
08-05-2016 10:56 AM Last Post: kjb |
| DidiDex 1984 Levin coupe rebuild | DidiDex | 1 | 6,988 |
08-13-2015 03:22 PM Last Post: DidiDex |
| Ae86 from Poland. Complete body rebuild | Doktor | 8 | 17,378 |
09-07-2013 11:07 PM Last Post: Doktor |
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100617_004.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100617_005.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100617_057.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100617_068.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100617_064.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100617_075.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100617_074.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100617_089.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100617_088.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100617_090.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100617_082.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100617_079.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100617_080.jpg)
..................but took over 2 months to get them all!! ![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100712_001.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100801_001.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100726_002.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100726_003.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100726_001.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100726_004.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100726_005.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100726_008.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100726_010.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100726_009.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100727_007.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100727_006.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100727_001.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100727_009.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100727_010.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100727_011.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100727_014.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100727_013.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100727_012.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100727_015.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100727_016.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100728_003.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100728_004.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100728_005.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100730_002.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100728_023.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100728_006.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100728_009.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100728_010.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100728_011.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100728_013.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100730_005.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100730_006.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100801_003.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100801_004.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100801_009.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100801_006.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100801_008.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100801_012.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100801_010.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100801_011.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100801_016.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100801_017.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100801_021.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100801_022.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100801_024.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100801_025.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100801_027.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100801_028.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100801_031.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100802_002.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100802_003.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100802_004-1.jpg)
![AEU86 AE86 - Tureno 4agte engine rebuild :D [Image: AEU86 AE86 - Tureno 4agte engine rebuild :D]](http://i144.photobucket.com/albums/r193/AE_92_GTi/20100803_002-1.jpg)
