Racecar: TRD USA built ITA AE86
10-10-2017, 08:16 PM
very cool ae86 i love those old vintage racing ae86's.
Definitely will be following this thread.
10-10-2017, 09:03 PM
Wow, that's indeed a challenge to replace the cluster! Huh
I fitted Euro MR2 lenses on my JDM bumper, but that's because regulations in Europe required it. I think in your case you need to have it either as one shared amber light (USDM), or the two separate amber lights (JDM). Personally I like the zenki one the best... Smile
[Image: AEU86 AE86 - Racecar: TRD USA built ITA AE86]
10-11-2017, 12:44 PM
Try salad oil on the residue should work magic Wink
Daily Beater: Civic EG5
Work in progress Car: AE86
10-11-2017, 08:45 PM (This post was last modified: 10-11-2017 08:47 PM by oldeskewltoy.)
(10-10-2017 02:58 PM)Bean Wrote:  I like the Zenki type, suites it well.
WD40 works for removing residues but it's very labour intensive.
WD-40 + a soft Scotch Brite pad + time + hot soapy water = ..........
front lamps finished... rear lamps left to do.......
I tried peanut butter, WD-40, and olive oil........ the peanut butter and olive oil (didn't have any "salad oil") did little or nothing.
The hot water was key.
More to come..... Hurray!
Dan -
10-19-2017, 12:44 AM
(10-09-2017 10:36 PM)oldeskewltoy Wrote:  there is no engine fan, mechanical driven or electric, has made me a bit uncomfortable. David (previous owner) said it wasn't a problem, after all this is a race car, it is used on track........
As this car's purpose has changed somewhat, besides the bits I've already mentioned, I'll be adding a thermo-switched electric fan to keep temps under control in less then perfect racing conditions.
More to come....... Hurray!
key part to getting the fan in, and operational is the proper parts. Below is a coolant inlet for an AE82. This will bolt in as the stock one does, and is even pointing in the correct place. The original Toyota switch is grounded, and when hot it breaks the ground(opens) and the fan comes on. This works as a safety as well, if the switch breaks, the fan stays on.
For Racecar I'm using a Honda switch, that will be open, and close @ temp (reverse of Toyota switch). This makes wiring the fan a bit simpler since the Honda switch is more conventional in operation.
BUT... the sensor doesn't quite fit. The hole for the probe is too narrow, and the threads aren't deep enough. So a few mods....
and the Honda switch becomes right at home....
with just enough of the sensor in the coolant to operate, yet not so far in that it seriously disrupts flow
more to come..... Hurray!
Dan -
10-19-2017, 07:44 AM
Wow. What a machine. I will follow this build. The cage has a diagonal cross member right? Is the shotgun seat even usable?
10-19-2017, 06:18 PM (This post was last modified: 10-19-2017 06:23 PM by oldeskewltoy.)
(10-19-2017 07:44 AM)Hama86 Wrote:  Wow. What a machine. I will follow this build. The cage has a diagonal cross member right? Is the shotgun seat even usable?
No shotgun seat anymore......
Dan -
10-20-2017, 11:03 AM
better design rollcage.
In the old days it would have shitty aluminium rollcage.
10-23-2017, 01:54 PM
dayum. What a car. I can also see impact absorbers on the driver side? (wavy sheet metal)
01-16-2018, 03:56 AM
oldeskewltoy Wrote:current livery...
The livery when built....
I will most likely returning it to her original livery.......... Wink
almost there........ Wink
still need to replicate a few pieces... but she is what she was...... Wink
more to come.... Hurray!
Dan -
  ae86 racecar with beams engine bakonick 148 195,674 04-23-2024 10:06 PM
Last Post: bakonick
  (Catching up) OST-086 MM: Built for Mario oldeskewltoy 2 3,654 10-28-2022 08:23 AM
Last Post: decryphe
  ae86 Trueno f20c Built to be driven not polished Martynas 45 65,251 05-29-2020 12:59 PM
Last Post: decryphe
  S.K.s AE86 racecar S.K. 207 260,857 09-18-2016 11:39 AM
Last Post: totta Crolla
  Built like an A-10 (Thunderbolt II aka Warthog) assassin10000 32 53,606 03-20-2012 12:33 PM
Last Post: assassin10000
