Project from Denmark
07-18-2017, 09:31 AM
Post: #71
I really hope so, with the amount of work I am putting in to it, and not to talk about the huge pile of money
![]() Got another update planed, so stay tuned for more boring rust work
Restoring my AE86, all the way... Going JDM style http://www.aeu86.org/viewtopic/ae86/p/150463#150463 |
07-18-2017, 09:28 PM
Post: #72
Time for some more work, this time I am working on the left rear side.
First I spent some time removing the old Rear quarter panel, took some extra time due to the old rust work I had done (solid welded it) But of it came, took the outer piece of the inner fender of too... ![]() ![]() A while back, I found a brand new outer piece of the inner fender ![]() ![]() The rear pocket needs some work, in order to become hole again. Got this cut from another car, its almost complete, and will make the fix much easier. ![]() ![]() Here I have cut out the rotten parts, and fitted the restored shell cut. ![]() After a bit of welding and grinding, the rear pocket is complete again.
07-25-2017, 09:25 PM
(This post was last modified: 07-25-2017 09:27 PM by Vaptor.)
Post: #73
A bit more rust work done
Was not quite finished with the rear pocket, forgot all about this small piece, that needed some work. ![]() After a bit work, it was ready to be put back on the car. ![]() When I cleaned the inside of the car, I noticed some rust along the inner wheel house, so took of the reinforced plates to have closer look. And it was a pretty site ![]() After a good cleaning, I could see the parts that needed to be cut out, in order to remove all the bad metal. ![]() Replaced the missing parts, with some fresh metal. ![]() After some welding and grinding, the reinforcement plates where back on the car again. ![]() Now there are no more rust, that hinders me from putting back some of the new body panels I have, can't wait
08-01-2017, 04:22 AM
(This post was last modified: 08-03-2017 05:18 PM by headrush.)
Post: #74
Well done man, that's an insane amount of work you've done there! I wish I had 1/1000th part of your skills!
Now you're entering the fun stage of putting your car back together |
08-23-2017, 11:13 PM
Post: #75
Finally time to fit some lager parts to the Shell
![]() I let the pictures speak for them self. ![]() ![]() ![]() ![]() Great to see some real progress Next I need to fix two holes behind the rear seats, then change the sills before I finally can put the Rear quoter panels and roof back on. Hope that by christmas it looks like a car again
08-24-2017, 08:28 PM
Post: #76
Wow! Nice progress! It looks like your car is getting some structure back!
08-24-2017, 08:46 PM
Post: #77
Yea. Finally it start to look like a car again.
08-30-2017, 08:44 PM
Post: #78
Excellent work, you must be very hand with a welder
![AEU86 AE86 - Project from Denmark [Image: AEU86 AE86 - Project from Denmark]](https://preview.ibb.co/f4f2N5/156.jpg)
![AEU86 AE86 - Project from Denmark [Image: AEU86 AE86 - Project from Denmark]](https://preview.ibb.co/fj0QaQ/157.jpg)
![AEU86 AE86 - Project from Denmark [Image: AEU86 AE86 - Project from Denmark]](https://preview.ibb.co/iJukaQ/158.jpg)
![AEU86 AE86 - Project from Denmark [Image: AEU86 AE86 - Project from Denmark]](https://preview.ibb.co/gBCMFQ/159.jpg)
![AEU86 AE86 - Project from Denmark [Image: AEU86 AE86 - Project from Denmark]](https://preview.ibb.co/guLvzk/161.jpg)
![AEU86 AE86 - Project from Denmark [Image: AEU86 AE86 - Project from Denmark]](https://preview.ibb.co/fFTyKk/162.jpg)
![AEU86 AE86 - Project from Denmark [Image: AEU86 AE86 - Project from Denmark]](https://preview.ibb.co/nffsC5/163.jpg)
![AEU86 AE86 - Project from Denmark [Image: AEU86 AE86 - Project from Denmark]](https://preview.ibb.co/bxEVzk/164.jpg)
![AEU86 AE86 - Project from Denmark [Image: AEU86 AE86 - Project from Denmark]](https://preview.ibb.co/iwgSek/165.jpg)
![AEU86 AE86 - Project from Denmark [Image: AEU86 AE86 - Project from Denmark]](https://preview.ibb.co/irYqzk/166.jpg)
![AEU86 AE86 - Project from Denmark [Image: AEU86 AE86 - Project from Denmark]](https://preview.ibb.co/f2xXU5/167.jpg)
![AEU86 AE86 - Project from Denmark [Image: AEU86 AE86 - Project from Denmark]](https://preview.ibb.co/jVU7wk/168.jpg)
![AEU86 AE86 - Project from Denmark [Image: AEU86 AE86 - Project from Denmark]](https://preview.ibb.co/juJp95/169.jpg)
![AEU86 AE86 - Project from Denmark [Image: AEU86 AE86 - Project from Denmark]](https://preview.ibb.co/dowLGk/170.jpg)
![AEU86 AE86 - Project from Denmark [Image: AEU86 AE86 - Project from Denmark]](https://www.aeu86.org/sticker-banner-468.gif)
