OST-078: Not the only one who signs their work.....
01-04-2022, 06:26 PM
![]() Well.... I'm not the only one who signs their work...... ![]() But what did he do???? I assume this head didn't pressure test back in 2003.... ![]() so he repaired it ![]() more to come.....
Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
01-06-2022, 04:46 PM
So what's the big deal.....???
When you invest $2000.00 on a head and cams, you want everything to be perfect, and I want it to be perfect too, as my reputation is worth a fair bit more............ So with the knowledge of this head going forward, I instruct the shop to be extra careful during the pressure check. ![]() Does anyone see what I see??? more to come.....
01-07-2022, 07:01 AM
(This post was last modified: 01-07-2022 07:04 AM by Bean.)
Head might have been skimmed quite a bit judging by the mark on the water outlet.
Missing discoloration on the intake port where the TVIS valves are, as well as the discoloration is different on the far left. AE86 ex-daily |
01-10-2022, 06:51 PM
(01-07-2022 07:01 AM)Bean Wrote: Missing discoloration on the intake port where the TVIS valves are, as well as the discoloration is different on the far left. I tend to call it the TVIS effect..... While the TVIS butterflies likely have some effect, I believe it also has to do with the offset injector port............ ![]() Note valves 1, 4, 5, and 8 are more heavily coated in carbon, they are NOT sprayed nearly as the other valves by the injector placement. It is similar effect that direct injected engines suffer - large build up of carbon. Port work begins.... 1 and 2/3 down........ ![]() more to come........
01-13-2022, 08:39 PM
3 down.........
![]() Along with the head work (including cams...) this client sent me his oil pump to massage as well. ![]() more to come.... Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
01-13-2022, 10:20 PM
Do you get the heads vapor blasted these days? That thing is impeccable.
How useful do you reckon the oil pump 'massaging' is? FABRICA MI DIEM, PVNC! |
01-17-2022, 05:33 PM
(01-13-2022 10:20 PM)Ivan141 Wrote: Do you get the heads vapor blasted these days? That thing is impeccable. I'm trying to persuade my shop to upgrade... the finish I'm getting is only after the head gets tumbled in zinc shot. As far as massaging the oil pump... the outlet from the pump gears (2) is the most crucial.... Additionally, I've had an idea I've yet to implement, in adding a 45 degree wedge at the galley outlet (1) where it mounts to the block ![]() 4 down.... ![]() Next step valve job, then getting chamber volumes to determine depth of final surface machining. more to come.......
01-21-2022, 05:46 AM
Back from its valve job... chamber volumes are measured, and equalized.....
![]() then back to the machine shop for surfacing, and back to my shop for final assembly, and setting cam clearances. Clearances set @ .008". ![]() Fitting faux cams to keep shims in place during shipping..... Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
01-23-2022, 01:37 PM
(01-21-2022 05:46 AM)oldeskewltoy Wrote: Fitting faux cams to keep shims in place during shipping.....That's clever! I think it's the little details like this that count! 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
02-03-2022, 08:52 PM
(01-23-2022 01:37 PM)banpei Wrote:(01-21-2022 05:46 AM)oldeskewltoy Wrote: Fitting faux cams to keep shims in place during shipping.....That's clever! I think it's the little details like this that count! I stumbled across this about 5-6 years back. I had a piece of plastic electrical use conduit and I noticed the circumference was nearly the same as the cam journals.... add a bit of tape in the right area and it allows me to set cam clearances, and safely ship the head, without the cams installed - safer with valves on their seats instead of open. Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
| (Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 3,779 |
| OST-093: My, My, Mystery | oldeskewltoy | 10 | 7,623 |
| (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 5,179 |
| (Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 3,399 |
| (Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 2,755 |
![AEU86 AE86 - OST-078: Not the only one ... work..... [Image: AEU86 AE86 - OST-078: Not the only one ... work.....]](https://gallery.ostportworks.com/albums/userpics/10005/OST-078.jpg)
![AEU86 AE86 - OST-078: Not the only one ... work..... [Image: AEU86 AE86 - OST-078: Not the only one ... work.....]](https://gallery.ostportworks.com/albums/userpics/10005/repair_person.jpg)
![AEU86 AE86 - OST-078: Not the only one ... work..... [Image: AEU86 AE86 - OST-078: Not the only one ... work.....]](https://gallery.ostportworks.com/albums/userpics/10005/repair_area_1a.jpg)
![AEU86 AE86 - OST-078: Not the only one ... work..... [Image: AEU86 AE86 - OST-078: Not the only one ... work.....]](https://gallery.ostportworks.com/albums/userpics/10005/normal_repair_area_1.jpg)
![AEU86 AE86 - OST-078: Not the only one ... work..... [Image: AEU86 AE86 - OST-078: Not the only one ... work.....]](https://gallery.ostportworks.com/albums/userpics/10005/after_disassembly.jpg)
![AEU86 AE86 - OST-078: Not the only one ... work..... [Image: AEU86 AE86 - OST-078: Not the only one ... work.....]](https://gallery.ostportworks.com/albums/userpics/10005/TVIS_explained_4_panel.jpg)
![AEU86 AE86 - OST-078: Not the only one ... work..... [Image: AEU86 AE86 - OST-078: Not the only one ... work.....]](https://gallery.ostportworks.com/albums/userpics/10005/1_5_down.jpg)
![AEU86 AE86 - OST-078: Not the only one ... work..... [Image: AEU86 AE86 - OST-078: Not the only one ... work.....]](https://gallery.ostportworks.com/albums/userpics/10005/3_down_smaller.jpg)
![AEU86 AE86 - OST-078: Not the only one ... work..... [Image: AEU86 AE86 - OST-078: Not the only one ... work.....]](https://gallery.ostportworks.com/albums/userpics/10005/ported_oil_pump.jpg)
![AEU86 AE86 - OST-078: Not the only one ... work..... [Image: AEU86 AE86 - OST-078: Not the only one ... work.....]](https://gallery.ostportworks.com/albums/userpics/10005/oil_pump_housing_annoted.jpg)
![AEU86 AE86 - OST-078: Not the only one ... work..... [Image: AEU86 AE86 - OST-078: Not the only one ... work.....]](https://gallery.ostportworks.com/albums/userpics/10005/4_down~1.jpg)
![AEU86 AE86 - OST-078: Not the only one ... work..... [Image: AEU86 AE86 - OST-078: Not the only one ... work.....]](https://gallery.ostportworks.com/albums/userpics/10005/checking_chamber_volume2~0.jpg)
![AEU86 AE86 - OST-078: Not the only one ... work..... [Image: AEU86 AE86 - OST-078: Not the only one ... work.....]](https://gallery.ostportworks.com/albums/userpics/10005/fitting_the_shipping_cam_blanks.jpg)
![AEU86 AE86 - OST-078: Not the only one ... work..... [Image: AEU86 AE86 - OST-078: Not the only one ... work.....]](https://www.aeu86.org/sticker-banner-468.gif)
