OST-070: 7AGE for an N2 Levin
09-07-2020, 05:28 PM
(08-29-2020 09:26 PM)Vaptor Wrote: The Exhaust gasket you are using here, what specific model is it, and from what company? The gasket was a collaboration between myself, and SV3* (before they closed). Essentially it is a Blacktop gasket(35mm port exit), that fits both 16V and 20V heads. It also has slightly "adjusted"(.020" down) bolt holes, for better port alignment. * - http://sv3power.com/_p=939/ unfortunately it is no longer available - (35mm sold out)... although I am trying to see if they will make more. I do know they do have about 8 of these gaskets remaining designed for full Atlantic ports - 38mm 35mm under 38mm ![]() now 3 down....... chambers.... ![]() and exhaust ports.... ![]() more to come.....
09-10-2020, 09:23 PM
Bowl #8... as it transitions from stock to oversize
a different perspective.... on the transition ![]() head is now ready for the new seats to be cut...... ![]() more to come...
09-12-2020, 09:16 PM
Love the details
![]() As I am going to use a TVS supercharger 900 or 1320 on my build, with High Lift cams, I was commended to go with 38mm (37mm) Exhaust port. Do you perhaps know if the 38mm gasket is a 1:1 copy of an TODA gasket? Just to compare what the local tuner recommends compared to your work, What diameter did you get the new bovls machined to? I think I read somewhere, that you use some old SR20 valves, when doing the chambers, is this correct? Is there a certain size valve that you use, or is it the same size, as the oversize 4age valves IN32mm EX28mm? Oversize valve work, is new to me. so hope that I can drain you for some knowledge
Restoring my AE86, all the way... Going JDM style http://www.aeu86.org/viewtopic/ae86/p/150463#150463 |
09-14-2020, 08:02 PM
(09-12-2020 09:16 PM)Vaptor Wrote: Love the details 1) copy of Toda - nope... ours is "better" ... because we took into account the gasket drop, so we adjusted ours .020" (bolt holes down, or if you prefer ports up) 2) the bowl/seat diameter (32mm/27.5mm) will be different depending on how much lift you are running.... under .350" lift - keep seat/bowl to 85%, over .400" lift - 88% I have used other valves to protect seats when I've done the chamber work in the past - when I have machined seat to protect, in this case the seats haven't been cut, so I didn't need to protect them. the pistons finally arrived.... ![]() more to come.....
09-23-2020, 06:30 PM
(This post was last modified: 09-23-2020 06:34 PM by oldeskewltoy.)
So... While this is going into an N2 replica, it is being fitted with timing covers to protect the timing belt, and to keep the cam seal retainers*. This requires some fabrication, as there never was a 7AGE, so the timing covers don't readily fit. Additionally, an idler is being added to the long side to eliminate belt slap.
* - not many realize that the rear timing cover is also used to keep the cam seals firmly in the head ![]() Essentially this is a 2 part job - part one, build the foundational parts(rear cover), part two - make a filler panel. ![]() So the rear cover is cut so that it can be lengthened, in this case it was also the area that was needing clearance for the idler. ![]() Note that the "clocking" of the bottom section has changed slightly... this is do to fitting this to a 7A block, as well as keeping the middle timing cover lower exhaust side mount correctly positioned. This type of work is easier done when using the block and head, while a jig could be made, this is easier.... but if a "production" version were to be made, a jig would likely be better. So this is what needs to be done to build a 7AG rear timing cover.... ![]() with all the mods performed...... (sans refinishing) ![]() and side by side..... ![]() more to come.....
09-23-2020, 09:27 PM
Nice work!
But it's a lot of work to keep it "stock" 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
10-13-2020, 05:24 PM
(09-23-2020 09:27 PM)banpei Wrote: Nice work!Not stock..... but part of the requirement on this job..... ![]() over coming "challenges"...... oldeskewltoy Wrote:Essentially this is a 2 part job - part one, build the foundational parts(rear cover), part two - make a filler panel. So, the filler panel would need to be light, and strong, and easily shaped - that would hold its shape. ![]() Aided by CAD (cardboard aided design)....... ![]() and the preliminary fabricated filler panel ![]() So.... besides the timing cover challenge, there were a few other "challenges" we had to overcome.... 1) the pressure plate (needed to balance the rotational assembly) never showed.... - lost in transit... AND.... 2) overcoming the "wrong" rods...... for some reason this set of 7AG Saenz rods were not machined for Toyota bearings..... ![]() This set of rods were somehow machined for Nissan SR20 rod bearings - where the tang sits further out then the Toyota bearing tang does.... the correct set of ACL bearings.... and all the rods are now @ .0017" More to come........
10-13-2020, 09:20 PM
Love the details
![]() Newer thought about the timing cover needed to be modded, but makes sense when the timing belt needs to be longer in order to fit an 7age ![]() Luckily I got a lot of those plates and covers to mod myself. Thanks for this detailed build tread
10-30-2020, 06:46 PM
(This post was last modified: 10-30-2020 06:46 PM by oldeskewltoy.)
A quick look at the "new" bottom end before it gets closed up.... can you spot any new balancing??
![]() So with the proper head gasket on order, some of the details need further planning... For one... what to do with a smallport head drain on an engine that didn't have a receptacle for the drain..... so a bit of work to be done on the MRP oil pan..... ![]() Adding a new bung.... and a bit of a trim to the flange - partially to look good, but also to allow a full parameter weld - this bung is not going to leak as it is welded on the inside, and the outside.. ![]() Also, as this is a 7A, the MRP pan needs a small spacer to keep the rods away from the internal windage tray. ![]() I have found that when closing up the bottom end, that stacking, could just be stock pan, and windage tray, or this combination - spacer and MRP pan, that using some dowels really helps keep things cleaned (fewer FIPG fingers) and easier to assemble ![]() more to come....
11-24-2020, 07:49 PM
Cometic delivered a new .023" (their thinnest) head gasket.... (the deck on this engine was .012" down)
making sure it is installed correctly... ![]() If installed incorrectly the red circles are where the oil drains would be... As you see, this build is using the ARP head stud kit...... torqued to 60 pounds ![]() with the slightly shorter stud in the distributor location ![]() more to come.........
| (Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 4,642 |
| OST-093: My, My, Mystery | oldeskewltoy | 10 | 9,619 |
| (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 6,454 |
| (Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 4,316 |
| (Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 3,450 |
![AEU86 AE86 - OST-070: 7AGE for an N2 Levin [Image: AEU86 AE86 - OST-070: 7AGE for an N2 Levin]](https://scontent.fhio2-1.fna.fbcdn.net/v/t1.15752-9/118854444_3348961085244589_8438786127522001270_n.jpg?_nc_cat=111&_nc_sid=ae9488&_nc_ohc=ZvxKIesN8kkAX-1uaD0&_nc_ht=scontent.fhio2-1.fna&oh=256a7a0797f8a9f302b6f5b1070c9fb8&oe=5F7C12ED)
![AEU86 AE86 - OST-070: 7AGE for an N2 Levin [Image: AEU86 AE86 - OST-070: 7AGE for an N2 Levin]](https://gallery.ostportworks.com/albums/userpics/10005/3_down_chambers.jpg)
![AEU86 AE86 - OST-070: 7AGE for an N2 Levin [Image: AEU86 AE86 - OST-070: 7AGE for an N2 Levin]](https://gallery.ostportworks.com/albums/userpics/10005/exhaust_port_3_down_1_to_go.jpg)
![AEU86 AE86 - OST-070: 7AGE for an N2 Levin [Image: AEU86 AE86 - OST-070: 7AGE for an N2 Levin]](https://gallery.ostportworks.com/albums/userpics/10005/short_radius_3_and_4_2_panel.jpg)
![AEU86 AE86 - OST-070: 7AGE for an N2 Levin [Image: AEU86 AE86 - OST-070: 7AGE for an N2 Levin]](https://gallery.ostportworks.com/albums/userpics/10005/ported_head_prior_to_valve_job.jpg)
![AEU86 AE86 - OST-070: 7AGE for an N2 Levin [Image: AEU86 AE86 - OST-070: 7AGE for an N2 Levin]](https://ost.ebeans.ch/albums/userpics/10005/new_pistons.jpg)
![AEU86 AE86 - OST-070: 7AGE for an N2 Levin [Image: AEU86 AE86 - OST-070: 7AGE for an N2 Levin]](https://gallery.ostportworks.com/albums/userpics/10005/timing_cover_3_panel.jpg)
![AEU86 AE86 - OST-070: 7AGE for an N2 Levin [Image: AEU86 AE86 - OST-070: 7AGE for an N2 Levin]](https://gallery.ostportworks.com/albums/userpics/10005/normal_20200923_090713.jpg)
![AEU86 AE86 - OST-070: 7AGE for an N2 Levin [Image: AEU86 AE86 - OST-070: 7AGE for an N2 Levin]](https://gallery.ostportworks.com/albums/userpics/10005/timing_cover_re-design.jpg)
![AEU86 AE86 - OST-070: 7AGE for an N2 Levin [Image: AEU86 AE86 - OST-070: 7AGE for an N2 Levin]](https://gallery.ostportworks.com/albums/userpics/10005/timing_cover_re-design_3_panel.jpg)
![AEU86 AE86 - OST-070: 7AGE for an N2 Levin [Image: AEU86 AE86 - OST-070: 7AGE for an N2 Levin]](https://gallery.ostportworks.com/albums/userpics/10005/rear_timing_cover_2_panel_7A_4A.jpg)
![AEU86 AE86 - OST-070: 7AGE for an N2 Levin [Image: AEU86 AE86 - OST-070: 7AGE for an N2 Levin]](https://www.aeu86.org/sticker-banner-468.gif)
![AEU86 AE86 - OST-070: 7AGE for an N2 Levin [Image: AEU86 AE86 - OST-070: 7AGE for an N2 Levin]](https://gallery.ostportworks.com/albums/userpics/10005/normal_timing_cover_middle_2_panel_-_filler_idea.jpg)
![AEU86 AE86 - OST-070: 7AGE for an N2 Levin [Image: AEU86 AE86 - OST-070: 7AGE for an N2 Levin]](https://gallery.ostportworks.com/albums/userpics/10005/CAD_timing_cover_filler_2_panel.jpg)
![AEU86 AE86 - OST-070: 7AGE for an N2 Levin [Image: AEU86 AE86 - OST-070: 7AGE for an N2 Levin]](https://gallery.ostportworks.com/albums/userpics/10005/timing_cover_mounted_preliminary_2_panel.jpg)
![AEU86 AE86 - OST-070: 7AGE for an N2 Levin [Image: AEU86 AE86 - OST-070: 7AGE for an N2 Levin]](https://gallery.ostportworks.com/albums/userpics/10005/bearing-rod_misalignment.jpg)
![AEU86 AE86 - OST-070: 7AGE for an N2 Levin [Image: AEU86 AE86 - OST-070: 7AGE for an N2 Levin]](https://gallery.ostportworks.com/albums/userpics/10005/assembled_short_block_crank_view.jpg)
![AEU86 AE86 - OST-070: 7AGE for an N2 Levin [Image: AEU86 AE86 - OST-070: 7AGE for an N2 Levin]](https://gallery.ostportworks.com/albums/userpics/10005/head_drain1.jpg)
![AEU86 AE86 - OST-070: 7AGE for an N2 Levin [Image: AEU86 AE86 - OST-070: 7AGE for an N2 Levin]](https://gallery.ostportworks.com/albums/userpics/10005/oil_pan_mod_2_panel.jpg)
![AEU86 AE86 - OST-070: 7AGE for an N2 Levin [Image: AEU86 AE86 - OST-070: 7AGE for an N2 Levin]](https://31625.smushcdn.com/527924/wp-content/blogs.dir/1127/files/2015/03/Sump-Spacer-1-500x333.jpg?lossy=1&strip=1&webp=1)
![AEU86 AE86 - OST-070: 7AGE for an N2 Levin [Image: AEU86 AE86 - OST-070: 7AGE for an N2 Levin]](https://gallery.ostportworks.com/albums/userpics/10005/oil_pan_alignment_2_panel.jpg)
![AEU86 AE86 - OST-070: 7AGE for an N2 Levin [Image: AEU86 AE86 - OST-070: 7AGE for an N2 Levin]](https://gallery.ostportworks.com/albums/userpics/10005/proper_gasket_alignment_2_panel.jpg)
![AEU86 AE86 - OST-070: 7AGE for an N2 Levin [Image: AEU86 AE86 - OST-070: 7AGE for an N2 Levin]](https://gallery.ostportworks.com/albums/userpics/10005/ARP_studs_head_mounted.jpg)
![AEU86 AE86 - OST-070: 7AGE for an N2 Levin [Image: AEU86 AE86 - OST-070: 7AGE for an N2 Levin]](https://gallery.ostportworks.com/albums/userpics/10005/ARP_short_stud.jpg)
