OST-058: "Q"
09-28-2019, 05:14 PM
OST-058: "Q"
[Image: AEU86 AE86 - OST-058: "Q"]
more to come...... Hurray!
Dan -
09-28-2019, 08:41 PM
OST-058: "Q"
Dumb question
10-01-2019, 12:12 AM
OST-058: "Q"
(09-28-2019 08:41 PM)banpei Wrote:  [Image: AEU86 AE86 - OST-058: "Q"]
Dumb question
Not a whole lot going through my mind....... Evil but of course 4AG head porting Angel
Recently I've acquired 5 20V 4AG heads. Two Silvertop, and three Blacktop
One of the Blacktop heads went to a client in Indiana, this head is #2 from that lot.... and it is available.... Huh
disassembled, ready to get cleaned
more to come.... Hurray!
Dan -
10-01-2019, 08:26 PM
OST-058: "Q"
the head came back pretty clean...
This was the first 20V head I spent any time on deburring the casting flash
Most of the casting flash was around the spark plug tube supports, and in the end areas. Some of the area are purposefully cast with a ledge, those areas stand out around the exhaust side bucket cylinders
More to come...... Hurray!
Dan -
10-03-2019, 03:07 AM (This post was last modified: 10-03-2019 03:07 AM by oldeskewltoy.)
OST-058: "Q"
and so it begins.... biggest thing on a Blacktop head is core shift... you can kind of see it in top photo's short radius as it isn't centered
Chamber #2 on top, chamber #1 on the bottom....
You can also see where I've done blending around the valve seats
Dan -
10-03-2019, 05:27 PM
OST-058: "Q"
working the bowls to correct the core shift, and to create "gentle" short radii.....
Dan -
10-04-2019, 01:12 AM
OST-058: "Q"
2 down... 2 to go....
Dan -
10-14-2019, 06:21 PM
OST-058: "Q"
with the port work finished, its off to the machine shop to get its valve job, and re-surfacing
more to come..... Hurray!
Dan -
10-22-2019, 06:47 PM
OST-058: "Q"
back from its valve job(ain't those back cuts purdy..... ), and re-surface... ready for re-assembly.
PS... this head still needs a new owner.......
Dan -
  (Catching up) OST-086 MM: Built for Mario oldeskewltoy 2 3,859 10-28-2022 08:23 AM
Last Post: decryphe
  OST-093: My, My, Mystery oldeskewltoy 10 7,784 09-18-2022 02:19 AM
  (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams oldeskewltoy 5 5,304 09-09-2022 09:07 PM
Last Post: Vaptor
  (Catching up...) OST-083: Salvage operation oldeskewltoy 2 3,486 07-11-2022 08:32 PM
  (Catching up...) OST-082: Nope, never again... at least not without all the parts oldeskewltoy 0 2,814 06-28-2022 09:17 PM
