OST-056: Nasty.....
05-01-2019, 07:01 PM
OST-056: Nasty.....
![]() Another first gen 4AG head, this one is a bit Nasty.... ![]() Btw, here is a photo showing the difference between a 1st gen TVIS head, and a 2nd gen TVIS head. A first gen is what came on the AE86, the 2nd gen is later ![]() So, getting back to OST-056, the head is stripped, cleaned(?), and pressure checked. Once back, I deburr the casting ![]() more to come......
Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
05-06-2019, 07:12 PM
OST-056: Nasty.....
from another forum Wrote:oldeskewltoy Wrote:Btw, here is a photo showing the difference between a 1st gen TVIS head, and a 2nd gen TVIS head. A first gen is what came on the AE86, the 2nd gen is later I've yet to see a Toyota application that uses that mount........... Work on the head proceeds..... "Building" the intake side - blending the seat, bowl, and port ![]() also working the exhaust side ![]() more to come......
05-10-2019, 09:05 PM
OST-056: Nasty.....
oldeskewltoy Wrote: A facebook "viewer" asked if my work fits the stock gasket... I assured him it does...... ![]() Further progress... 3 down... 1 to go ![]() more to come.......
05-11-2019, 05:16 PM
OST-056: Nasty.....
(05-06-2019 07:12 PM)oldeskewltoy Wrote:from another forum Wrote:oldeskewltoy Wrote:Btw, here is a photo showing the difference between a 1st gen TVIS head, and a 2nd gen TVIS head. A first gen is what came on the AE86, the 2nd gen is later AE92
05-12-2019, 01:47 PM
OST-056: Nasty.....
Dan
I believe best practice is to match the top of the exhaust port with the header gasket [highest flow area] and leave the step mis-match at the bottom of the port for anti-reversion? Dave W |
05-14-2019, 02:00 AM
OST-056: Nasty.....
Project D -
from another forum Wrote:I'm sorry I derailed the topic with this, but I guess we all learn something new every day. And I always love to see your work! oldeskewltoy Wrote:After learning about AE92 the timing cover...... (05-12-2019 01:47 PM)Dave W Wrote: Dan There isn't much to work with... most of my improvements take place inside... but on some heads..... that is why I worked with SV2 to help design the copper exhaust gasket - http://www.sv3power.com/store/index.php?...cts_id=217 Not only is it bigger, but part of the design was moving the bolts holes down (or exhaust ports up) by .020" How it looks/fits.... ![]() But this head isn't going to see that much exhaust port work.... more to come....
05-14-2019, 10:53 PM
OST-056: Nasty.....
(05-12-2019 01:47 PM)Dave W Wrote: DanThe pictures are taken with the head upside down Sent from my MHA-L29 using Tapatalk AE86 ex-daily |
05-17-2019, 12:15 AM
OST-056: Nasty.....
(05-14-2019 10:53 PM)Bean Wrote:(05-12-2019 01:47 PM)Dave W Wrote: DanThe pictures are taken with the head upside down ahh, I'm sorry I thought the ports being upside down was obvious... my apologies.... back from the machine shop wearing a new 3 angle, and back cut intake valves.... ![]() next, checking chamber volumes... ![]() So if I want chambers down to 36cc, how much should I have machined from the head??? more to come....
05-17-2019, 12:47 AM
OST-056: Nasty.....
It's very late so my math might be off but I think about 1.5 thou (inches) sounds wrong but that's all I can come up with right now. I'm rusty with my numbers and a bit tipsy.
05-17-2019, 05:52 PM
OST-056: Nasty.....
(05-17-2019 12:47 AM)Bean Wrote: It's very late so my math might be off but I think about 1.5 thou (inches) sounds wrong but that's all I can come up with right now. I'm rusty with my numbers and a bit tipsy. well, about .008" is about 1cc(+ or -), so @ .6cc over, that would be about .005" ![]() and that's how much I had it machined..... more to come....
| (Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 3,601 |
| OST-093: My, My, Mystery | oldeskewltoy | 10 | 7,279 |
| (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 4,914 |
| (Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 3,197 |
| (Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 2,605 |
![AEU86 AE86 - OST-056: Nasty..... [Image: AEU86 AE86 - OST-056: Nasty.....]](http://ost.ebeans.ch/albums/userpics/10005/OST-056.jpg)
![AEU86 AE86 - OST-056: Nasty..... [Image: AEU86 AE86 - OST-056: Nasty.....]](http://ost.ebeans.ch/albums/userpics/10005/disassembly2.jpg)
![AEU86 AE86 - OST-056: Nasty..... [Image: AEU86 AE86 - OST-056: Nasty.....]](http://ost.ebeans.ch/albums/userpics/10005/4AGE_TVIS_heads_early_late_annoted.jpg)
![AEU86 AE86 - OST-056: Nasty..... [Image: AEU86 AE86 - OST-056: Nasty.....]](http://ost.ebeans.ch/albums/userpics/10005/disassembly_deburred_2_panel.jpg)
![AEU86 AE86 - OST-056: Nasty..... [Image: AEU86 AE86 - OST-056: Nasty.....]](http://ost.ebeans.ch/albums/userpics/10005/3_multipanel.jpg)
![AEU86 AE86 - OST-056: Nasty..... [Image: AEU86 AE86 - OST-056: Nasty.....]](http://ost.ebeans.ch/albums/userpics/10005/exhaust_3_panel_one_down_3_to_go.jpg)
![AEU86 AE86 - OST-056: Nasty..... [Image: AEU86 AE86 - OST-056: Nasty.....]](http://ost.ebeans.ch/albums/userpics/10005/exhaust_port_4_vs_3_smaller.jpg)
![AEU86 AE86 - OST-056: Nasty..... [Image: AEU86 AE86 - OST-056: Nasty.....]](http://ost.ebeans.ch/albums/userpics/10005/3_down_1_to_exhaust_and_intake_view__multi_panel.jpg)
![AEU86 AE86 - OST-056: Nasty..... [Image: AEU86 AE86 - OST-056: Nasty.....]](https://i.postimg.cc/KjTK1Nd4/ae92-4age-timing-cover-brackets.jpg)
![AEU86 AE86 - OST-056: Nasty..... [Image: AEU86 AE86 - OST-056: Nasty.....]](https://i.postimg.cc/V6d081gq/ae92-4age-cam-bracket-sticking-out.jpg)
![AEU86 AE86 - OST-056: Nasty..... [Image: AEU86 AE86 - OST-056: Nasty.....]](https://i.postimg.cc/DZHJfDpt/ae92-4age-timing-cover-backside.jpg)
![AEU86 AE86 - OST-056: Nasty..... [Image: AEU86 AE86 - OST-056: Nasty.....]](http://ost.ebeans.ch/albums/userpics/10005/comparing_3_to_2_2_panel.jpg)
![AEU86 AE86 - OST-056: Nasty..... [Image: AEU86 AE86 - OST-056: Nasty.....]](http://ost.ebeans.ch/albums/userpics/10005/showing_3_angle_and_back_cut.jpg)
![AEU86 AE86 - OST-056: Nasty..... [Image: AEU86 AE86 - OST-056: Nasty.....]](http://ost.ebeans.ch/albums/userpics/10005/measuring_chamber_volumes_2_panel_36_6cc.jpg)
![AEU86 AE86 - OST-056: Nasty..... [Image: AEU86 AE86 - OST-056: Nasty.....]](http://ost.ebeans.ch/albums/userpics/10005/_6cc_math.jpg)
