OST-053: Massaging a 20V Blacktop
02-15-2019, 02:10 AM
![]() My client asked me to overhaul his Blacktop (for his AE86). It comes to me with a spun #2 rod bearing (atypical, in my exp usually it's #4). The rod is toast, and the crank would need to be turned. "Would", not "will". My client isn't a fan of a turned crank, so we have ordered a new one. And as far as rods go, I have a set of re-worked TRD (20mm pins now) rods, that I'm selling him. ![]() here is the head during disassembly ![]() some grunge, but I've seen worse ![]() Here are the cleaned block, head, valves, and associated parts. Using the back of my car as a pick up...... ![]() more to come..... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
02-19-2019, 05:15 PM
from another forum Wrote:What method did you use to get the head so clean? I work with a couple of machine shops, part of the fees in doing head work is a professional cleaning, and checking the casting for its pressure holding ability - make sure there are no porosity issues from another forum Wrote:Oooh, that's pretty neat. There are 2 significant differences. The first is at lower level lifts, the intake side flows much better. At higher lifts, the flow tends to get closer, beginning to equalize. The second major difference is the exhaust size is significantly larger. With that said... a ported 16V std valve head can be made to do everything, except equal the 20V @ low lifts. having all the other projects now finished, or waiting on parts, I ficus on the Blacktop head - working the intake side first. #1 in the right, #2 on the left. ![]() more to come.... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
02-21-2019, 06:54 PM
further progress, this time on the exhaust side......
![]() more to come....... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
02-23-2019, 11:28 PM
Sorry if I’m digging into something I shall not: how did you get a new crank, and how much was it? They tend to cost a fortune I heard :o
02-25-2019, 10:18 PM
(02-23-2019 11:28 PM)domi007 Wrote: Sorry if I’m digging into something I shall not: how did you get a new crank, and how much was it? They tend to cost a fortune I heard :oAbout $450..... 13401-16020 https://www.toyotapartsdeal.com/oem/toyo...16020.html Now as far as a European supplier... I can't help there.... Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
02-26-2019, 01:18 AM
Also available in Europe. Price is around 450/500€
Nice work on the 20V! ![]() |
02-27-2019, 06:11 PM
(02-26-2019 01:18 AM)pack Wrote: Also available in Europe. Price is around 450/500€ ![]() from another forum Wrote:Excellent work as alway OST. I’m finally able to revisit my Blacktop project of 7 years ago. This is inspiring - makes me want to get on it. any inspiration I can help with is all good! sometimes... it helps to see from a different POV...... I've added a photo to the above multi-panel ![]() for the sharp of eye who follow my work, the above castings are from OST-034, but they still hold true...... as before, and after exhaust porting on a Blacktop head. More to come...... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
02-28-2019, 01:19 AM
What is your honest feedback on the TRD conrods for the 20v?
I know i need to rebuild my 20V, not sure if bore walls are STD, if not, big pistons will follow and obviously new conrods (just because). Not sure what to purchase... |
02-28-2019, 06:42 PM
(02-28-2019 01:19 AM)pack Wrote: What is your honest feedback on the TRD conrods for the 20v? I've had this set of rods for a while... in fact this set's been to Europe and back (sold, and then returned). BUT you don't need to spend BIG money for decent rods. While I have only this anecdotal experience with blacktop rods, this engine's bearings appear to just be old worn out parts - all the bearings were pretty bad. But for the most part OEM rods are plenty strong. As an example of stock rod durability, my smallport is running a 40mm rod journal crank and stock 3 rib 40mm rod journal rods - albeit with new bolts. I'm making 140 ish whp, and I twist it regularly up to 7500+ and it now has over 30k miles on it. But if you just want better (stronger, and lighter) rods, I usually recommend Molnar Technologies. They run about $450 per set. ![]() Port work continues.... 2 down.... 2 to go ![]() more to come.... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
03-01-2019, 06:59 PM
(Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 3,406 |
OST-093: My, My, Mystery | oldeskewltoy | 10 | 6,894 |
(Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 4,767 |
(Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 3,046 |
(Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 2,403 |
