OST-045: 5AGTE... again ;)
01-18-2018, 12:46 AM
![]() As arrived. The head has been cleaned, but I don't know if it has also be pressure tested, so I'll be sending it out, along with all the associated bits to get cleaned and pressure checked before I start work. ![]() The buckets and shims have seen better days... replacing them with good used units is far less costly then trying to salvage these More to come.......
01-19-2018, 07:57 PM
work begins.... de-burring the casting......
![]() more to come......
01-23-2018, 04:20 AM
![]() working the first set of bowls and seats..... more to come.......
01-25-2018, 02:03 AM
2 down.... 2 to go....
01-26-2018, 08:33 PM
Just about done on the intake side.........
01-27-2018, 02:41 AM
![]() next... the exhaust side.... more to come........
02-01-2018, 12:05 AM
(This post was last modified: 02-01-2018 12:15 AM by oldeskewltoy.)
![]() Chamber work has begun..... more to come.......
02-05-2018, 10:51 PM
3 chambers down......
![]() sometimes the right tool is the simplest.... working the chamber wall with 120 grit. ![]() ![]() more to come....
02-08-2018, 05:51 PM
Chambers done...... (for now)
work begins on the exhaust side.... one done... one under construction ![]() more to come......
02-09-2018, 02:11 PM
Dan
Have you send any dyno testing that would indicate that the 4AGE would see favorable power gains by incorporating anti-reversion step in the exhaust port - header. I've already increased the exhaust port by about 3mm, but was thinking about grinding out the header I.D. at the head attachment face. Dave W |
| (Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 3,910 |
| OST-093: My, My, Mystery | oldeskewltoy | 10 | 7,843 |
| (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 5,365 |
| (Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 3,515 |
| (Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 2,843 |
![AEU86 AE86 - OST-045: 5AGTE... again ;) [Image: AEU86 AE86 - OST-045: 5AGTE... again ;)]](http://ost.ebeans.ch/albums/userpics/10005/ost-045.jpg)
![AEU86 AE86 - OST-045: 5AGTE... again ;) [Image: AEU86 AE86 - OST-045: 5AGTE... again ;)]](http://ost.ebeans.ch/albums/userpics/10005/head_unpacked.jpg)
![AEU86 AE86 - OST-045: 5AGTE... again ;) [Image: AEU86 AE86 - OST-045: 5AGTE... again ;)]](http://ost.ebeans.ch/albums/userpics/10005/cleanup_casting_2_panel.jpg)
![AEU86 AE86 - OST-045: 5AGTE... again ;) [Image: AEU86 AE86 - OST-045: 5AGTE... again ;)]](http://ost.ebeans.ch/albums/userpics/10005/intake_4_done_vs_3_untouched.jpg)
![AEU86 AE86 - OST-045: 5AGTE... again ;) [Image: AEU86 AE86 - OST-045: 5AGTE... again ;)]](http://ost.ebeans.ch/albums/userpics/10005/intake_2_panel.jpg)
![AEU86 AE86 - OST-045: 5AGTE... again ;) [Image: AEU86 AE86 - OST-045: 5AGTE... again ;)]](http://ost.ebeans.ch/albums/userpics/10005/intake_3_panel.jpg)
![AEU86 AE86 - OST-045: 5AGTE... again ;) [Image: AEU86 AE86 - OST-045: 5AGTE... again ;)]](http://ost.ebeans.ch/albums/userpics/10005/intake_4_panel.jpg)
![AEU86 AE86 - OST-045: 5AGTE... again ;) [Image: AEU86 AE86 - OST-045: 5AGTE... again ;)]](http://ost.ebeans.ch/albums/userpics/10005/2_chamers_down__2_panel_annoted.jpg)
![AEU86 AE86 - OST-045: 5AGTE... again ;) [Image: AEU86 AE86 - OST-045: 5AGTE... again ;)]](http://ost.ebeans.ch/albums/userpics/10005/3_chambers_down2C_one_to_go.jpg)
![AEU86 AE86 - OST-045: 5AGTE... again ;) [Image: AEU86 AE86 - OST-045: 5AGTE... again ;)]](http://ost.ebeans.ch/albums/userpics/10005/hand_working_the_chamber_smaller.jpg)
![AEU86 AE86 - OST-045: 5AGTE... again ;) [Image: AEU86 AE86 - OST-045: 5AGTE... again ;)]](http://ost.ebeans.ch/albums/userpics/10005/one_done2C_one_under_construction.jpg)
