Koen's 86 - every drive a new issue
07-22-2025, 10:10 PM
I have 15x7 0J Konig Rewinds and those did not fit without some rubbing (especially the fronts, but rear could touch too). Silver with polished lip btw....
07-23-2025, 12:09 AM
Normally I'm not a fan of green cars, but that shade of green looks really gorgeous.
Someone in Japan even made a model of your car (not really, but it looks almost identical). |
08-08-2025, 05:39 PM
(07-22-2025 10:10 PM)Ivan141 Wrote: I have 15x7 0J Konig Rewinds and those did not fit without some rubbing (especially the fronts, but rear could touch too). Silver with polished lip btw.... Hmm, not promising. I guess with 195/50R15 tires? Going a bit narrower makes it easier I hope I've bought them, so I'll try it some time. (07-23-2025 12:09 AM)Power_uP Wrote: Normally I'm not a fan of green cars, but that shade of green looks really gorgeous. Awesome! That's a lot of detail for a driftbody on a RC car. Looks very similar indeed. I do have a set of redlines to copy the model but I'm missing the Equip's and the Ganador mirrors so I guess I'll leave the car as is ![]() So on my to-do list for the silver car was fitting new valve seals due to some blue smoke from the exhaust. It started producing this after a small trip on the motorway. Followed the guide on this website https://www.aeu86.org/how-to-3/engine/di...tem-seals/ and started opening the motor. I've bought all the suggested tools including the adapter to put air in the cilinder except for the valve stem pliers (which I did need ). The tools are really cheap in the Chinese webshops these days. Worked fine ![]() After removing the camshafts I found some marks on the caps and the camshafts themselves. Not very promising. After fitting the new seals I tried the car and the issue is still there. The experts think it ran without oil at some point in its life and resurrecting the car last year with 2.000km of driving probably made it worse. So it needs a new engine ... winterproject Well, at least the other car is still working. Went to JCS and tested my wiring booth fix. It worked ![]() And did some driving to celebrate 86-day a few days ago. Ran fine, so I guess it's done for now
09-10-2025, 11:35 PM
So I did some 86 stuff last month. Not a lot of actual building/repairing but did collect some parts and saw some cars.
First I found an engine for the silver car. It's a 7-rib big-port from an MR2 with the 42mm crank. It popped up on marktplaats and I decided to buy it. It was low mileage (according to the odo-meter) and it ran so that's something. Does anyone know if my stock ECU will run this? (after transferring all the bits to make it RWD again of course, only the bottom-end and cilinder-head will be from the MR2) And while picking up the engine I found the grommets for my green car They are used to guide the wiring from the "boot" to the headlights in the MR2 ![]() A week later I went to see a Black Limited in real life. And some other cars of course. This was at 86Fest in Ireland. Took a plane because the silver car wasn't running The show was different this year with a lot of other old Toyota's and even some newer cars on track. But nice nevertheless. Nicest car on track was a K-swapped N2 kitted white Levin, but I forgot to take a photo ![]() And this red rally car really drew my attention. It runs a 1300cc Suzuki engine with 200hp, a sequential and a Ford rear axle. Really cool build with an insane amount of modifications (coilovers with moved pickup-points, dry-sump, Ford swaybars, electric powersteering, digital dash, fiberglass everything, ect). 800kg and in some <1300cc class (hence the Suzuki engine). So this gave me some inspiration for a new stupid plan. I've decided that I want to do some amateur rallying in 2026+. And for this I need a car. I don't have much experience so I don't want a fast car in some class where I would be a moving roadblock. So a 86 would be perfect Almost every rally in NL and BE is starting to add historics. Here you can drive with old, "slow" cars and just have fun. After some research I figured out that it would be very difficult to enter with my green car. The amount of modifications allowed are very strict. Basically you have to follow the homologation of your car for the correct era if you want to be in the historic class. The AE86 has a Group N and Group A homologation (https://historicdb.fia.com/car/toyota-co...oor-ae86-0 ) which means my throttle-bodies, exhaust manifold, gearbox, rear-axle, wilwood-brakes and some other bits aren't allowed. So I had a good reason to get another car and there was one for sale for quite a while. It has all the correct bits and there is room for some improvement when I want to make it faster (it's allowed to fit a 5-speed dogbox, a shorter diff-ratio, decent coilovers all around and some adjustable suspension arms). It already has a rebuild engine with cams, programmable ECU in original casing, period AP-brakes and the correct cage. All this is checked by the FIA if it complies with the homologation and logged in a Historic Technical Passport. So it can enter the historic class ![]() Only disadvantage was that it was located in Sweden but after a long roadtrip it's now in NL. Previous owner is a true rally and 86 enthusiast. He's 72 years old and has 50 years of rally experience. He's still driving his other 86 rally car! Also has another complete Levin 3-door shell for sale with a cage and LSD rear axle. Rust free, looks straight and has all the panels/glass. Only missing the engine and interior. Even comes with Danish papers to get it on the road again. If anyone wants to start a track/drift/rally project, this is definitely the cheapest way to do it. So now I can spend the winter tiding up this car and get it registered ![]() It needs a bigger brake mastercilinder. Any advice? It has to look OEM the booster is the 2 hole version (non-EU I believe)
09-11-2025, 07:20 AM
Wow! You've had some great 86-experiences!
That Suzuki-powered rally car certainly is very interesting. About the homologation: yes, those FIA specifications are quite strict. If I remember correctly, Toyota homologated a few more options later throughout the AE86 life with stronger rear axles and such. But everything is supposed to be OEM-Toyota. About fitting your current ECU to the 7-rib engine: this depends on the engine specifications. Here in Europe, the non-cat engines are supposed to have a higher compression ratio (10.0:1 versus 9.4:1) as it would be allowed to run on leaded gasoline. This means the fuel maps between cat and non-cat are different. Similar to the AE86, the MR2 came with cat and non-cat versions. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
09-12-2025, 07:45 PM
Sick! Can't wait to see it
(09-11-2025 07:20 AM)banpei Wrote: About fitting your current ECU to the 7-rib engine: this depends on the engine specifications. Here in Europe, the non-cat engines are supposed to have a higher compression ratio (10.0:1 versus 9.4:1) as it would be allowed to run on leaded gasoline. This means the fuel maps between cat and non-cat are different. Similar to the AE86, the MR2 came with cat and non-cat versions.Don't think that would matter that much, ofcourse its not optimal but the stock ECU is probably not optimal anyway. Have been experimenting in my NA MX5 for several years with NB 1.8 engines (Similar compression bump like the 4ages) on stock NA 1.8 electronics. Drove alot of km's and did several drift days without any faults. |
11-07-2025, 08:00 PM
(09-11-2025 07:20 AM)banpei Wrote: About the homologation: yes, those FIA specifications are quite strict. If I remember correctly, Toyota homologated a few more options later throughout the AE86 life with stronger rear axles and such. But everything is supposed to be OEM-Toyota.Yes, I've figured out that everything should be correct. I can't even switch between parts in the VO's (the lists of options they added to the homologation during the years). So this makes life simple. I can't change anything ![]() (09-11-2025 07:20 AM)banpei Wrote: About fitting your current ECU to the 7-rib engine: this depends on the engine specifications. Here in Europe, the non-cat engines are supposed to have a higher compression ratio (10.0:1 versus 9.4:1) as it would be allowed to run on leaded gasoline. This means the fuel maps between cat and non-cat are different. Similar to the AE86, the MR2 came with cat and non-cat versions. I'm not sure which version I have to be honest ... I probably just try DarkSupra's method ![]() So did some work to the cars last month. Very busy so not a lot of time left. But I've signed up for a regularity at night for the end of this month (basically finding the correct road as designed by the organizers on an old fashioned paper map) so I have to add lights to the car (and it looks cool The green car already came with a light bar when I bought it. I've never fitted it, so I took it it out storage. The brackets are there which saves a lot of time. And it probably gives a lot of light, but it's not very pretty in my opinion So did some modifying. Some painting, added an extra "level", new wiring and installed fog's from marktplaats instead of two spotlights (also makes it 4x Hella 2000's) And now it looks like this ![]() A lot better I think of course it involved some changes to the loom to make everything switchable with the high-beam and it gave me the opportunity to install the interior lights which is quite handy at night. Everything works Also switched to the Rial Mesh wheels because the Longchamps don't match with the lights but for some reason these need 25mm spacers (instead of 15mm) to clear the brakes which makes them rub. I guess I have to find some with a higher offset or change them again. The grey car is disassembled a bit currently. The previous owner was about 30cm shorter than me and his seating position was too high. So I need to make different (lower) seat mounts in the car. Also removed the dash (and all the other stuff) because everything was a bit crooked. Now I can fix all this and reinstall it a bit more straight ![]() Does anyone know how the fuse box in the drivers footwell (LHD)is usually mounted? They removed all the panels and it hangs on one bolt. I prefer to make it better and a bit more protected... I probably have the parts somewhere, but I don't know how they look
11-08-2025, 08:07 PM
Yeah light setup looks way better now!
Only thing missing are the minilites or revolutions ![]() ![]() (11-07-2025 08:00 PM)Koen Bongers Wrote: Does anyone know how the fuse box in the drivers footwell (LHD)is usually mounted? They removed all the panels and it hangs on one bolt. I prefer to make it better and a bit more protected... I probably have the parts somewhere, but I don't know how they lookThink mine is still mounted how it should, I'll take a look if I don't forget. |
12-20-2025, 02:58 PM
(11-08-2025 08:07 PM)DarkSupra Wrote: Yeah light setup looks way better now! Yes, that's the look I was after! Didn't work out since I had to put the Longchamps back on to stop rubbing the fenders and I have enough wheels so I decided not to buy another set haha. But the car managed to survive two days of driving across boarders! Had great fun exploring a lot of narrow and sometimes unpaved roads. The navigation is quite tricky (it's all about driving the correct road, not so much about going fast) so we became next to last ![]() Car looks used afterwards ![]() Did some work to the grey hatch. Turns out that having a car that is checked for homologation doesn't mean that it will pass technical inspection. So it needs some mods. ![]() Changed the seat mount to sit lower. Started converting the fuel lines to flexible, braided AN hoses. Found a electric powersteering set on 2dehands.be thanks to DarkSupra and my Lampola T50 arrived from Finland ![]() And a friend re-sleeved the original wiring loom for the interior to make it look a lot cleaner ![]() No big updates, but work continues slowly. |
02-21-2026, 06:39 PM
(This post was last modified: 02-21-2026 06:41 PM by Koen.)
It's been a while since I've updated. I still forget to take pictures
so I've pushed the grey car outside today to show some of the progress.The new fuel system is (almost) ready and in the car ![]() I made a new fuel pump cradle to change everything to AN6. It uses the original mounting holes for the tank (and the seal). The Bosch pump that was in the car is reused. As seen in a previous post I've cut a hole in the floor to acces the fuel pump cradle. Way easier to replace a pump in case something happens. Also gives me some more room for all the fittings. I've put a metal box over it (the lid needs changing, ran out of aluminium ) to keep it separate from the cabin (regulations, safety)In the box is now also the fuel-filter. Declutters the engine bay a bit. The wiring needs a connector and I have to add a roll-over valve to the breather but that's about it. Then all new braided flexible lines to get the fuel to the engine. These are now in the car instead of underneath. Made a bulkhead feed-through for all the lines (brake line and the fire extinguisher is also added) And made flex-lines in the engine bay to feed the original fuel-rail with the added fuel pressure regulator (which was on the car already) So this part is done. As you can see in the pictures I did more already. There is some new paint in the interior. I've replaced the dashboard with one which does have al the mounting points (but still is in bad shape, so I want to replace it when I find a better one). Driver and passenger foot plates are ready and I've started assembling the brake system. Also the green one got a fresh MOT (without any work )I've installed the dashboard and some parts but it seems that something is missing for the heatersystem. Does anyone know how it looks? Than I can start searching in the pile
| all wheel drive 3SGTE corolla | qwoson | 3 | 6,788 |
03-23-2008 01:50 PM Last Post: Gtsi-R |
![AEU86 AE86 - Koen's 86 - every drive a new issue [Image: AEU86 AE86 - Koen's 86 - every drive a new issue]](https://www.aeu86.org/sticker-banner-468.gif)
![AEU86 AE86 - Koen's 86 - every drive a new issue [Image: AEU86 AE86 - Koen's 86 - every drive a new issue]](https://i.ytimg.com/vi/cfhGo7lmzic/maxresdefault.jpg)
