How to fit rear wheel studs without removing the shafts?
11-18-2010, 04:42 PM
I've read that it's possible to do it, but haven't found an explanation Sad
Can someone please point me in the right direction?
http://www.autoreverb.com - Loud automotive passion.
11-18-2010, 09:21 PM
Push the stud in from the back and get the splines lined up.
Put a heavy flat washer over the exposed thread.
Put a standard wheel nut on the stud backwards (flat side to washer).
Put oil or grease on the thread and between the nut and the washer.
Pull the stud into the hub by tightening the nut.
Note that it is important to have studs with the correct spline diameter.
Cheers... jondee86
11-19-2010, 10:29 PM
Thanx mate!
  Pinout of some connectors needed for removing JB2 Koen 4 2,341 04-01-2026 07:27 PM
Last Post: Koen
  Spare wheel & spare wheel carrier ondafly 6 1,894 01-19-2026 01:00 PM
Last Post: ondafly
  Mistlamps don't fit gh0st 1 3,893 10-14-2021 09:00 PM
  Can you identify this wheels? Will they fit AE86? Ryo 8 15,047 09-08-2021 12:48 PM
Last Post: Ryo
  Half Shafts Poblem AlexKTM 6 9,997 04-23-2018 04:42 PM
Last Post: MIGGZFSU
