Hot oil filter - a problem?
01-01-2014, 04:19 PM
Hi
Using an aftermarket exhaust my oil filter gets very hot. Has anyone heard of reliability issues because of this? I am wondering how it affects my oil temperature. A relocation kit would be "easy" but also add another component that can fail. |
01-01-2014, 06:03 PM
I had the same problem with my exhaust header. I was actually blistering the paint on the oil filter. I made a cylindrical shaped heat shield, and attached it to the filter with a hose clamp. I have about a 4mm air gap between the filter and the heat shield which was enough to resolve problem. Dave W
01-02-2014, 10:56 AM
common problem with aftermarket headers as they ditch the original heatshield. Make a new one like Dave or have the header heatwrapped.
In general if you got a good oil cooling system it will be fine while driving. I would address it though especially for the moment when you stop. the header will still be hot but no more oilflow this might heat the oil inside the filter to a level where it might start building up and get caked and in turn block flow. AE86 ex-daily |
01-02-2014, 04:39 PM
My header is already wrapped but fabricating some sort of shield is a good idea - thanks!
01-03-2014, 09:33 PM
have you think to use a spacer to the header?
4age 16v to FR 20VT |
| ITB filter options | mister86 | 1 | 5,635 |
12-06-2020 10:44 AM Last Post: Bean |
| Placement location fuel filter | bozu | 0 | 5,102 |
12-01-2016 11:06 AM Last Post: bozu |
| Bluetop AFM with air filter | izanagi | 4 | 10,028 |
04-29-2016 07:29 PM Last Post: oldeskewltoy |
| trans oil, lsd oil change | Apolan | 9 | 22,646 |
| Engine cranks slowly when hot... but starts | Dino86 | 9 | 18,634 |
02-03-2014 08:04 PM Last Post: Dino86 |
