High-beam warning lamp
07-20-2023, 05:06 PM
Hello everybody,
I'm experiencing some issues with my headlights; on full beam the blue warning lamp is really dim, barely detectable by the human eye.
Has anyone experience of this?
The earth is good, the other warning lights (door open, fuel) are much brighter.
When it's lit, it's only getting 6volts which appears to be correct to as per the wiring diagram, ie. I series with the low beam so 6v + 6v = 12v. Should it be a different rated bulb? 6v as opposed to 12?
Any guidance appreciated
07-20-2023, 08:13 PM
Don't worry, all sorted now
07-20-2023, 11:22 PM
What was the cause then? Dumb question
[Image: AEU86 AE86 - High-beam warning lamp]
07-21-2023, 12:35 AM
I had mixed up the terminals at one of the headlights, effectively putting the main and dip filaments in series and taking 6v from between them to feed the warning light
07-21-2023, 07:44 AM
(07-21-2023 12:35 AM)Mylesmck Wrote: [ -> ]I had mixed up the terminals at one of the headlights, effectively putting the main and dip filaments in series and taking 6v from between them to feed the warning light
Thanks!
That explains it indeed.
  Blacktop 20V high idle Bravothreezero 3 1,074 08-28-2026 01:11 PM
Last Post: jdm86gtz
  How to: Repair low fuel warning sender Sanity Clause 3 42,765 05-19-2025 11:05 PM
Last Post: Sanity Clause
  Engine stress at high speeds gh0st 6 6,487 08-30-2022 07:11 PM
Last Post: Power_uP
  4AGE 16V engine overheat when at high speed chenfon 32 40,396 12-31-2020 06:39 AM
Last Post: chenfon
  Bonnet lamp pod for AE86 Dino86 0 4,436 01-04-2018 11:08 PM
Last Post: Dino86
