Help! tire rubbing problem
09-13-2007, 07:39 PM
I mounted my SSR 15x8 off -2 in the front with toyo proxes t1r 195/50 but i cant steer fullout. It touches the place where two panels comes together (velsrand?). Are there people who have experience with this?
[Image: AEU86 AE86 - Help! tire rubbing problem]
09-13-2007, 08:24 PM
I don't know how much it rubs. Maybe that you can "hammer" that lip a bit?
Or adjust your caster?
Only ideas though...
09-13-2007, 08:31 PM
ja gewoon platrammen een beetje,het komt omdat die wielen iets breder zijn
09-13-2007, 08:36 PM
TE71corolla Wrote:ja gewoon platrammen een beetje,het komt omdat die wielen iets breder zijn
ja zat ik ook al aan te denken maar wist niet of ik dan me body naar de maan zou helpen Wink
09-14-2007, 03:18 AM
I had the same problem with my set of Sportmax 15x8 offset 0. The tyres are the same.
Try heating up the plastic and then bend it a litle.
Or, just wait until the tyre is able to bend the plastic... or break it.... like in my case! Tongue
86'LEVIN Track Project
09-14-2007, 07:29 AM
I had the same problem on my car I just cut the seam back and re welded it..
Corolla Levin SR 1984 AE-85 (Project car)
Corolla Runx Z 2002 (Runabout)
  4agZe problem solved - 99% IC problem Okami 41 52,404 07-12-2012 04:49 PM
Last Post: Okami
  Idle problem!!! HELP!! panda_tureno86 6 9,252 02-28-2012 07:47 PM
Last Post: panda_tureno86
  Engine / cooling fluid problem need help asap... Okami 11 19,135 02-15-2011 01:34 PM
Last Post: Okami
  4AGZE problem...I Need help please guys ash16valve 6 9,987 12-11-2009 04:48 PM
Last Post: ash16valve
  AC problem? Idle problem? KD2229 3 6,855 08-19-2009 02:08 AM
Last Post: KD2229
