Help! tire rubbing problem
09-13-2007, 07:39 PM
I mounted my SSR 15x8 off -2 in the front with toyo proxes t1r 195/50 but i cant steer fullout. It touches the place where two panels comes together (velsrand?). Are there people who have experience with this?
09-13-2007, 08:24 PM
I don't know how much it rubs. Maybe that you can "hammer" that lip a bit?
Or adjust your caster? Only ideas though... |
09-13-2007, 08:31 PM
ja gewoon platrammen een beetje,het komt omdat die wielen iets breder zijn
09-13-2007, 08:36 PM
TE71corolla Wrote:ja gewoon platrammen een beetje,het komt omdat die wielen iets breder zijn ja zat ik ook al aan te denken maar wist niet of ik dan me body naar de maan zou helpen
09-14-2007, 03:18 AM
I had the same problem with my set of Sportmax 15x8 offset 0. The tyres are the same.
Try heating up the plastic and then bend it a litle. Or, just wait until the tyre is able to bend the plastic... or break it.... like in my case!
86'LEVIN Track Project |
09-14-2007, 07:29 AM
I had the same problem on my car I just cut the seam back and re welded it..
![]() Corolla Levin SR 1984 AE-85 (Project car) Corolla Runx Z 2002 (Runabout) |
| 4agZe problem solved - 99% IC problem | Okami | 41 | 47,981 |
07-12-2012 04:49 PM Last Post: Okami |
| Idle problem!!! HELP!! | panda_tureno86 | 6 | 8,558 |
02-28-2012 07:47 PM Last Post: panda_tureno86 |
| Engine / cooling fluid problem need help asap... | Okami | 11 | 17,866 |
02-15-2011 01:34 PM Last Post: Okami |
| 4AGZE problem...I Need help please guys | ash16valve | 6 | 9,264 |
12-11-2009 04:48 PM Last Post: ash16valve |
| AC problem? Idle problem? | KD2229 | 3 | 6,383 |
08-19-2009 02:08 AM Last Post: KD2229 |
![AEU86 AE86 - Help! tire rubbing problem [Image: AEU86 AE86 - Help! tire rubbing problem]](http://www.driftparts.nl/Eric/Spaanbanaan.jpg)
![AEU86 AE86 - Help! tire rubbing problem [Image: AEU86 AE86 - Help! tire rubbing problem]](http://img39.imageshack.us/img39/4898/profilepick.jpg)
