Flywheel fitting
09-04-2013, 10:36 PM
Flywheel fitting
I can't remember
Do the flywheel holes only line up in one position on the crankshaft ? thanks An analogue brain in a digital World |
09-05-2013, 12:18 AM
Flywheel fitting
There are eight holes in a circle... you can put it on any way you like
Some people say you should match mark the flywheel to the crankshaft. But IMHO, if the flywheel has been balanced, and the crankshaft has been balanced, I don't see that there is a need for match marking. I didn't do it on mine, and have yet to see any problem. Most important thing is to torque the bolts using the correct tightening pattern. Cheers... jondee86 |
09-05-2013, 12:35 AM
Flywheel fitting
Yes it was the balance question really and I wonder if Toyota balanced everything together as a unit or balanced individual items separately ?
09-05-2013, 01:45 AM
Flywheel fitting
Difficult to conceive the factory balancing the parts bolted together, and
then taking them apart to assemble the engine. I see balance divots on the crankshaft and on the flywheel, so I think you can assume they are balanced by their respective manufacturers. And I'm sure if they had to go together one particular way, there would be a locating dowel. Cheers... jondee86 |
09-05-2013, 08:20 AM
Flywheel fitting
Good morning my friends,
i have a 4age 16v ae92 and intending to install a 4age 20v flywheel!whats your opinion? 4age 16v to FR 20VT |
09-05-2013, 08:48 AM
Flywheel fitting
Get the Blacktop (AE111) flywheel... you'll love it
09-05-2013, 09:40 AM
Flywheel fitting
Good point about respective manufacturers and I kind of assumed that Toyota would do everything in house but of course you are right in what you are saying, parts will be outsourced.
It all makes perfect sense and I will go ahead and fit my flywheel without worry Thanks Jondee An analogue brain in a digital World |
09-05-2013, 10:59 AM
Flywheel fitting
jondee86 Wrote:Get the Blacktop (AE111) flywheel... you'll love it oh my God!!! make my day mate!!! it is 6 kg i think ?
09-05-2013, 11:00 AM
Flywheel fitting
totta Crolla Wrote:Good point about respective manufacturers and I kind of assumed that Toyota would do everything in house but of course you are right in what you are saying, parts will be outsourced. Good luck mate, i am waiting for news
09-05-2013, 11:21 AM
Flywheel fitting
There's balancing and then there is balancing. My experience so far showed that factory parts are quite unbalanced for my taste. I.e. a few grams whereas the parts I had balanced are within tiny fractions of a gram.
AE86 ex-daily |
| Fitting Air Con (No PS) to LHD AE86 | pack | 7 | 8,640 |
01-07-2024 11:36 AM Last Post: CCB |
| Fitting Fibreglass Kouki Lip? | chrisae86 | 3 | 4,429 |
02-25-2022 08:14 PM Last Post: chrisae86 |
| light weight Flywheel | filh | 9 | 11,905 |
02-05-2018 05:20 PM Last Post: filh |
| Fitting driftworks CS2 coilovers | bozu | 2 | 6,989 |
05-30-2017 10:50 AM Last Post: bozu |
| crank 6 bolt flywheel | DJexor | 5 | 11,348 |
12-05-2016 08:21 AM Last Post: d3nso |
